[B] Please Help Speedometer Accuracy[/B]
When the transmission assembly is swapped from a legacy with 4.444 gears into a svx with 3.54 gears, is the speedometer accurate, and if so what component swap makes it so.
Re: [B] Please Help Speedometer Accuracy[/B]
Iirc, use the SVX's stock speed sensor and tire diameter, and you should be good to go, as the speed is taken from the front axle's rotation and at no point before that.
my 4.44 changed my mph up about by about 4. so if it says 55 I am actually doing 51.
Thanks for the replies, I apreciate the correct information. I also agree that the speedometer will be correct.
Now I am wondering how this affects the application of the transfer clutch, since the speed of the rear end is taken prior to the reduction in the gears. |
Note; Once again, the speedometer will read 5.5% higher than actual vehicle speed due to the disparity of tire sizes between the doner cars tire size, and the SVX's tire size.s
www.svxfiles.com The first SuperCharged SVX, the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 07-24-2009 at 11:59 AM. |
I thought the Legacy (not Outback), Impreza, and SVX shared the same diameter (barring very modern 17s and very ancient 14s)?
The 225/50/16 tire that the SVX uses is 24.86" tall.
