Need driver's side runner
The plastic part that is under the driver's door snapped off this morning for no explicable reason. I have the beige interior. Does anyone have this part?
Re: Need driver's side runner
I have a couple with the same problem. The plastic clips get brittle and snap after repeated contact with your foot getting in and out. I am on my 3rd set.
They come complete with the new clips and white plastic inserts. They are still available from Subaru. The beige sill part numbers are 94010PA090DO (RH) $48.78 94010PA080DO (LH) $48.78 /
Thanks John. Would you suggest this route versus using some 3M industrial strength double sided sticky tape?
However, before installing the new sills, I put clear RTV sealant under each end before snapping in the new clips. This prevents any sliding movement back and forth, which can contribute to the failure. You could also put the RTV on the metal piece, on both sides of each clip, for added strength. Be sure to clean the underside of the sills, well as the metal, with a degreaser of some sort ( I use denatured alcohol) .
I like the RTV idea. I hate the idea of $50 for a piece of plastic. We have used 3M VHB tape at work with some great results. Here is a PDF of all the versions they have available. 4932 and 4952 look promising as do a couple of others. What you see here is that there are many different thicknesses available and some are better than others at sticking to "slippery" plastics.
I have a few perfect door sills in beige that don't have the clips. It would be nice for these to be reused by someone here. Its easy to take off the slippery surface of the plastic; just a quick wipe with acetone or lacquer thinner Great work, Tony. .
It turns out that most of these tapes only come in extremely long rolls. Even their automotive line tends to be sold in cases.
http://3mcollision.com/products/tapes/attachment-tapes I measured the white clips that hold onto the runner's tabs. It was about .055" thick. The automotive tapes come in .045" and .060" thicknesses. I'm thinking of using the .060" tape and keeping the clips in place. An alternative would be to use the .045" tape but first remove the clips. http://www.amazon.com/3M-Automotive-...=2MSVJQXLH0Q6R I'm also thinking of using the following product to repair part of the door seal that pulled away from the little plastic clips that hold it: http://www.amazon.com/3M-08008-Black...=2MSVJQXLH0Q6R
I looked a little more closely at the runner itself and now I am leaning toward just buying a new one. It looks like it is designed to be pushed up on one side by the carpeting so that the lip on the other side sits flush on the car body. That is probably another reason why these tend to break. Those tabs, which get brittle, are also under constant tension/torque. Why in the world didn't they just use screws?
The problem is that, to do this right with tape, you would have to use two different thickness tapes or use just one thickness right down the middle and remove the tabs from the car. Part of me still wants to see if I can make the tape work and the other part is saying to just get the expensive plastic part.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 06-09-2011 at 01:50 PM. |
I purchase my shipping supplies from Uline.com and they have some reasonable prices, especially on their branded tapes. Also wonder if carpet tape would work?
Gene
Gene and Ben 1992 SVX LS AWD 110K - Liquid Silver 1994 SVX LSi AWD 128K - White Pearl (daily driver) 1994 SVX LSi AWD 95K - Emerald Pearl (sold) 1992 SVX LS-L AWD 115K - Dark Teal 4.44 swap (sold) Last edited by bwb3; 06-09-2011 at 01:54 PM. |
