#331
Re: Individual Throttle Bodies and Improved Airflow
The injectors can be just above, and aimed at the rollers. The injectors above the ram tubes would be inviting a fire. OK with open intakes, but with enclosed intakes, a backfire would be nasty. Harvey.
#332
Hi Harvey,
I agree with you about going in the bend of the ram pipe with the injectors I just need to wait till they arrive. If the pipe is thick enough then thats way I will go other wise I will have to rethink them. Looked at the existing air box and its all to small for the high volume we need, going in through the front is the best option, its just a matter of do I make one large airbox or 2 smaller ones. Tony
#333
Use one large one, the air box has to be large enough to allow the sound waves to completely expand, as if the ram pipe opened into the atmosphere. If it is too small the wave will not deliver the same intense pressure wave to the cylinder. Harvey. Harvey.
#334
I have measured the restriction in the air box and its pretty bad at higher revs, so I will change it. Yes I will run a air cleaner my guess 2 of the current ones side by side. The other plus side of the bigger air box is if I have to install the injectors at the top of the pipes I can use the air box frame to do it. Does anyone know of any road cars with injectors at the top of the intake pipe? Tony
#335
Yeah the S70-2 engine in the Mclaren F1
#336
Hi Adam,
What do you think, were would you put the injectors?
#337
The primary injectors, or secondaries? Realistically, you may run into packaging issues with your roller throttles, and the tract length that you prefer to run. Due to the short tract expected and the spacing required to conceal the roller barrels inside the billet housings you'd likely find the current OEM location unfit as they simply cannot fit in the current orientation. Moving the injectors outwards(away from the port) results in poor feed angle and will certainly result in poor fuel injection into the airflow and poor atomization. This is where one may have to look into alternative injector style for better packaging. One cannot simply move the primary injectors pre-throttle plate/roller. The motor simply will not run at low throttle input. Many high RPM engines(super sport bikes, F1, the Mclaren F1 I mentioned) have a full set of secondary injectors that atomize directly into the ITB velocity stacks for proper fuel atomization at high intake velocities associated with short tract ITB setups, but still retain a full set of primaries at the port for low speed operation. The large diameter side feed style SVX(Sti) type injector may not be the best suited for this application where one is not retaining the OEM lower runner/injector boss casting and one may have to covert over to a more common bosch(Ford Motorsports) style top feed injectors and fuel rail setup that would allow a proper feed angle, still be able to clear the mechanics of the roller throttles, and allow you to retain a shorter tract length. There are also long nose injectors as well which allow for increase injector standoff distance form the actual throttle mechanism. One has to take into account that you're setting up a system onto a HEAD that was never designed for it, and more importantly the intake port was never designed for it. Impossible?, no. But one just has to realize there may be a compromise necessary that one really doens't want to take. |
#338
Thanks for that Adam, I am waiting on the ram pipes from the UK to work out how much height I have left under the bonnet. If I can get a further 20mm I should be good to put the injecter in the standard location. I will aim for that first.
A further question you cut the web out from between the two rollers so they could touch, on mine I have a .3mm gap between the two rollers. I am becoming concerned that this might be to much to enable proper idle. What do you think? If this is the case I can either make the rollers each .3 mm larger diameter or make the roller off centre so they get closer as they rotate. Was there any learnings you can pass onto me when you did yours? Tony
#339
I agree with Adam.
#340
between .15 and .25mm(~.005"-.010") is the range to try and work with but .3mm isn't that far off so I'd say you should be fine. Remember you can always machine things off further though.
Try and use either brass or graphite composite rod for the rollers. Avoid aluminum and ferrous metals. |
#341
I went with brass as you suggested.
Tony
#342
Might have to try the graphite as the brass is just to heavy and doesn't move very easily. Also I think I may have to redesign the throttle so I can use a reamer to make sure the roller pockets are the even. Also looking at putting bearings on each roller but that will be a pain in the ass.
Tony
#343
It amazes me I still don't own one of these. I was eyeing the SPI version back when it took me several tries over several days to get the spindle on my machine truly square. I'm going to redo some stuff on my machine and think I'll get one this go around.
Have you used a mist system that was effective at clearing chips out of your parts? Quote:
#344
do u guys think that not having the cover under the front part of the car on would effect the air flow to the airbox? newb question.. but jw. (by cover, i mean that huge plastic piece that is place under the car where the engine is, to block out rocks etc)
#345
It's usually called a "belly pan". More for aerodynamics than airflow ether to the intake or cooling the engine. The airbox pulls air from inside the right fenderwell, so it wouldn't be affected either way.
