Old 05-28-2012, 02:15 PM
kjoyes kjoyes is offline
hazard lights work but, blinkers don't!
plus, it won't shift out of park.
Old 05-28-2012, 02:17 PM
Re: hazard lights work but, blinkers don't!
Check all the fuses. Underhood and the ones inside the car. Do you know where they are?
Old 05-28-2012, 02:19 PM
yes, one is behind the battery and the other is in the side kick panel on the drivers side.
I just replaced the Rear sidemarker bulb# 168 both were blown out.
Old 05-28-2012, 08:12 PM
I checked the fuses none were blown.
i put in a new aftermarket stereo would that cause this to happen.
Old 05-28-2012, 09:08 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Did you have the drivers side knee panel off? Check the connector for the parking light switch. When that is disconnected, weird things happen.
Old 05-28-2012, 09:34 PM
i tried my parking light switch, and my parking lights came on, so i dont think it's unhooked.
whenever i press in the shift lever, there clicking sound down by the driver side dash. i think it is a relay.
would the factory security system, when i installed my radio the security was activated and did the locked the shift lever.
found this on a search.
There are several possible answers to this problem. First, check to see if you have brake lights. If not, check the fuse that supplies power to the brake lights. (my 2001 outback is #16 20amp located behind the coin drawer in the dash). If it is blown, replace the fuse and push on the brake pedal. If it blows again, you have a short in the system. Most commom fix is to replace all the brake lights. Sometimes they short out the system, blow the fuse and that will keep the car from shifting out of park. If the brake lights do not keep the fuse from blowing, it could be the brake solenoid located at the top of the brake pedal, or it could be the shift lock solenoid located to the right of the shifter under the cover. The easiest way to check these items is to unplug the wiring harness one at a time and then replace the fuse and see if it blows when you press on the brake. My fix was the shift lock solenoid. It isn't super hard to replace and can be found online or at a local wrecking yard.
I have a '94 Subaru Impeza and I took all the plastic parts out from around the shifter and on the right side is the locking pin that rises and falls when you pushed the button. This tends to get dirty and sticks. Clean as much as possible and spary WD-40 or silicone. It will take care of the problem.
I also found that if you have a weak battery or bad battery connection this can also cause the same issue.
Old 05-29-2012, 02:29 PM
immortal_suby's Avatar
Thread Killah
If all else fails check the turn signal relay mounted under the steering column. It's in a soft rubber cover. Replacement can be bought fairly low priced at any parts store.
http://www.autozone.com/autozone/par...fier=6416_0_0_
Locker Link
2015 BRZ Limited 6MT
Old 09-10-2012, 06:10 PM
Stevebsy's Avatar
Stevebsy Stevebsy is online now
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
Did you resolve this problem?
I have a similar problem.
My hazards work, but turn signals, reverse lamps, and shifter lockout don't work.
The fuse was blown and blew immediately again when I replaced it.
Otherwise everything else is ok. Is it the turn signal relay, or something worse?
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 09-10-2012, 06:24 PM
If it's blowing the fuse immediately, you have a direct short. Check for any pinched or cut wires.. Or put in a very strong fuse and keep an eye out for smoke (I don't actually recommend the last one)
Old 09-10-2012, 06:38 PM
Thread Killah
I'd swap out that turn signal relay first - they are pretty cheap.
Locker Link
Old 09-10-2012, 06:41 PM
Stevebsy's Avatar
Administrator
That's what I figure, but it blows out when nothing is activated (brake, signal, or in reverse)
The instant the fuse touches the contacts in the fusebox, it goes poof! so it is something pretty seriously shorted out.
Guess it's time to dig up the FSM if nobody else has had this issue.
'20 Honda Ridgeline
Old 09-10-2012, 07:06 PM
Thread Killah
That's what mine did when the turn signal relay went out. I put in a bigger fuse......smoke under the steering column. It's actually how I figured out the relay was bad. I think I remember it buzzing also.
edit: it didn't blow until the key was turned on IIRC
Locker Link
Old 09-22-2012, 12:24 PM
Stevebsy's Avatar
Administrator
I found my problem after a couple hours troubleshooting.
First I replaced the turn signal relay as suggested, and it did work briefly until I took it for a spirited drive. I noticed that when it was shifting from 1-2, it seemed that the engine stalled a little, but really that was the connector shorting out at that time. I later noticed that the signals weren't working again
So..I went home and I went to the FSM and followed where the current from the fuse went, and disconnected everything along its path under the dash/steering column but still no good. The only thing left was the reverse switch from the transmission. I reached under there are moved things around, and woot, all was good again.
It was the twin connector that goes to the transmission, at the rear of the engine bay. Since long ago and a few transmissions, the clips that hold those connectors in place broke off, so the connectors were just floating around there. It seems that one of them moved just into the right place to short out the reverse light circuit.
Now I'll put everything together and zip tie the trans connectors down and should be all good.
So lesson learned, zip tie down the transmission wiring connectors if your clips are broken.
'20 Honda Ridgeline
Old 09-22-2012, 05:03 PM
my problem turned out to be the turn signal fuse had blown.
