#91
Well there goes that theory. What year did you get?
#92
I have them and the info at work, maybe Bill remembers...
This picture is in my locker..
#93
-Bill
#94
Just an update for those of you who are curious. My 6 speed just passed Jersey State Inspection the other day with the Stage 2v5 ECU. Figured I would let other's know
Tom |
#95
Tom, Did the inspection include emissions? If it did, can you post the figures for HC, CO2, etc. -Bill
#96
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
#97
I am not sure that I still have the readouts... I will look for them. No way, i didn't pay anyone... the guy couldn't even find out how to use reverse!!
Tom |
#98
Tom:
What pressure was your FPR set at for the emissions test? Stock (~35 psi) or higher?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#99
I still have the stock FPR
TOm |
#100
ok found my emissions read-out
HC- 22... Standard-100 CO%- 0.00... Standard- 0.50 CO2% 15.1... Standard-... This is all that is relevant in NJ inspection I guess. Please take not that they only have 2wd rollers so my emissions are based on revs in neutral Tom |
#101
Tom, Great! The key here is that you're not even close to any of the maximum allowable levels! -Bill
Retired NASA Rocket Scientist Most famous NASA "Child" - OSIRIS-REx delivered samples from asteroid BENNU to Earth in Sept. 2023 Center Network Member #989 '92 Fully caged, 5 speed, waiting for its fully built EG33 '92 "Test Mule", 4:44 Auto, JDM 4:44 Rear Diff with Mech LSD, Tuned headers, Full one-off suspension '92(?) Laguna, 6 spd and other stuff (still at OT's place) My Locker Last edited by SVXRide; 01-06-2006 at 08:14 PM. |
#102
I cannot promise the same results to others. People with other than stock exhaust fpr and maybe some busted vaccum lines might have different #'s. I know that my engine runs very well
Tom |
#103
Just ordered my stage 2 - I can't wait!
#104
Didn't get a chance to do much more than a lap around the block - I'll have to post after some more driving next week.
#105
Stage 2 with a CAI makes a nice difference. Pulls a lot better in traffic now. Can't wait till everything is installed and I can see how the SVX performs with all mods on.
1992 SVX LS-L: Now TomStock Stage 3... 6MT, R180 Rear, Tomstock Short Shifter and hard rubber mount, Group N Motor and Tranny Mount, Stage 2V6 Chip, Z32 MAF, Stage 3 CAI, Stebro, Intake Cams, 17" STi BBS Powder Coated Black, Bridgestone Potenza RE070, and Koni inserts w/Mychailo's Springs! Sand Diego SCCA Solo 2 #308 RIP 84 VW Scirocco 02 WRX 88 XT6(regret the day I left her behind) socaleuro.com They like the flat 6... Check My New Homepage.. |
