Old 08-23-2011, 04:04 PM
A little smoke from the drivers side
What is around the drivers side of the engine that could be dripping onto the the exhaust. My valve cover gaskets and front and rear seals were changed within the last year and a half but something is leaking enough on the exhaust to give me a bit of smoke in that area. Could it be a Power Steering line?
Old 08-23-2011, 04:07 PM
Re: A little smoke from the drivers side
Trans cooler lines are over there. P/S is on the other side.
Old 08-23-2011, 04:21 PM
could be axle grease
what does it smell like/ what color is the smoke
Old 08-23-2011, 04:23 PM
Hmmm that's not good, time to crawl under and do some investigation.
Old 08-23-2011, 08:12 PM
It looks like it must just the valve cover gasket again. I think that the lower right corner maybe leaking a bit.
Old 08-23-2011, 08:22 PM
I bet the gasket got pinched out of the groove that it's supposed to sit in. Happens sometimes, and that's the corner least likely to be noticed if it were to happen. A little RTV on the corners isn't a bad idea, so it will hold them in place on the valve cover until you get them seated on the head.
That job is sooooooo easy with the engine on a stand...
Old 08-23-2011, 08:48 PM
..and such a ***** with it in.
