Old 10-05-2007, 06:23 PM
mbtoloczko's Avatar
sans SVX
Originally Posted by Crazypolo95 View Post
hey what kind of top mouths are those?. and how much was the set over all. Cuz i just may want some
For all new parts, cost is around $1675 + I need your old struts. Spring rates are based on your driving habits. Color is your choice.
Mychailo
Visit my locker
Old 10-05-2007, 06:38 PM
wawazat??'s Avatar
Yeah, I'm still around
Originally Posted by mbtoloczko View Post
Yeah, it turned out nice. I figured that there should be at least one more picture of a set of trick Koni/GCs on the network. ;-)
How's the handling with your spring rate combo? Seems to be a larger difference in front/rear rate than what I've seen by others. Is that rear spring 9" or 10" long?
awww, shucks Thanks
Handling is good but I need to reduce understeer further. I'm going to up rear rate with new springs this winter and then make the larger rear bar. Uping the rear pressure on the tires has had a dramatic impact on rear rotation. 38 psi is my favorite setting with 45psi up front. I can't recall the rear spring length off the top of my head, but I believe it's 8".
I'm building the anti-sway bar bending machine frame this weekend I have a Hossfeld bender with all the dies. I can even do roll-cage tubing with it...when I get the hydraulic power-pack for it that is.
Nice work and I need to talk to you about the rear mounts.
Todd
Down to none
Old 10-05-2007, 08:57 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
If either of you guys are still making/selling a bigger rear swaybar lemme know
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-05-2007, 11:44 PM
wawazat??'s Avatar
I'm not ready to offer them to the general public yet. When I do it will be complete with adjustable endlinks and the bar will have three settings.
Todd
Down to none
Old 10-06-2007, 01:05 AM
Dessertrunner's Avatar
Mychailo I checked the rear mounts and the bolts are smaller did I miss understand you?
Old 10-06-2007, 04:12 PM
Hmmm...with the Megan Racing group buy not looking so good I may be getting in touch with you about something just like this over the winter.
My old struts have been subjected to 15 Canadian winters (snow, salt, and nastyness). Would you still want those, or would I be paying the core cost?
Old 10-06-2007, 08:28 PM
mbtoloczko's Avatar
sans SVX
I mainly need just the bodies. As long as the bodies are too badly rusted, I could take them.
Mychailo
Visit my locker
Old 10-06-2007, 08:35 PM
mychailo, you had asked about the 450 front rates on my car... Seems to be a great fit for my car... Handles wonderfully at the auto-x and they don't really push at the limit at all... Now for some sway bar upgrades and I will be all set...
Old 10-07-2007, 10:10 AM
mbtoloczko's Avatar
sans SVX
Hi Tony, I think there might be a misunderstanding. The rear mounts I'm using on the Koni/GC setups would work well for your driving. Finding fronts that work for your driving would need further research. Seems that a few people are dimpling their hoods with the Koni struts after big potholes, etc, so other people might start researching this too. The SVX front top mount does not have an equilateral triangle bolt geometry (most top mounts are equilateral triangle) making it necessary to drill at least one new hole in the strut tower to use a substitute mount from another car.
Mychailo
Visit my locker
Old 10-07-2007, 10:23 AM
shotgunslade's Avatar
I now am the proud owner of a dimpled hood. Would love any intelligence about a beefier front top mount.
Old 10-08-2007, 04:04 AM
My DMS have a spring retainer that won't fit through the mount so my bonnet didn't get damaged.
Old 01-12-2008, 09:12 AM
Crazypolo95 Crazypolo95 is offline
95pologreen
Send a message via AIM to Crazypolo95
So is this till going cuz i need to net some new sturts fast and soon.
Crazypolo95: Cost is around $1675 + your old struts.
Tony: The rear mounts shown should be tough enough for offroad duty. I haven't researched a replacement for the front because they have been good enough for road duty, but I would think that one of the Gruppe-N mounts with a hard rubber bushing could be adapted. They'd be louder than stock, but shouldn't be horribly noisey like a pillow-ball setup.
AF: You never got the parts or your money back from Porter?
Old 01-12-2008, 10:16 AM
mbtoloczko's Avatar
sans SVX
PM'ed you.
Mychailo
Visit my locker
Old 01-12-2008, 02:14 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Todd
Todd and his toys!
Very, very nice! Eliminates the need to heat treat to bring the strength back up (yes, it's a hassle...). How big a diameter of solid stock will you be able to handle? Got a local supplier of 4130?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 01-12-2008, 03:43 PM
Banned
verry nice
wish I was rich those look sexy I'd love a set on my SVX but I'm afraid I am way too poor!
