EGR Error Codes
A few weeks ago, the check engine light came on and it was throwing a 56 error code (EGR valve). It was going to the shop anyway, so I asked them to check it out. The service manager then asked me if I had a chip, (which I do: Stage 2 v4) because, according to him, that code is handled by a chip that goes in the expansion slot that the Ecutune chip goes into. I didn't want to get into cross finger pointing issues, so I just told him to replace the EGR vlave, which he did, and the problem went away. Now I have an intermittent check engine light and it is throwing a 55 code (EGR temperature sensor). It is off now, but who knows if it will come back. I note in the trusty SVXipedia that these two codes 55 and 56 have a "(CA)" after them. I was wondering if these were for California emissions only and if the expansion slot really is for a California emissions control chip. If that is so, am I getting phantom codes. If not, does anyone think driving through high water might cause a 55 code. In case anyone didn't know, its been raining here is New Jersey lately. I'm thinking of building an ark just big enough for my wife and I and the SVX.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
I have been told that driving through a cold puddle will throw a check engine code.
