#421
Tom |
#422
I prefer venting when breaking in, or if I am expecting a blowby issue (stock motor). I think once you are done breaking in and dynoing, a catch can will help keep your engine bay clean. Also I'm not into the smell that much. Its really up to you though. I vented my WRX engine for almost 70k then switched to a catch can.
Chuck D. 1992 Subaru SVX LS-L - Heavily modded turbo 2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods |
#423
well... motor is basically done... I took off all of the stage 3 components and cleaned them up while also refinishing the engine... Teaser, no pics till she is running. I changed the oil in the blower as well... I am waiting on cams... Then it is off to final assembly and installation next weekend. I doubt I will find time this week
Tom |
#424
Power
Looks like your torque peak is comming a bit earlier and your HP peak a bit later. That's real good. I doubt there is any need to go much above 6300 rpms with this setup, so I probably won't need to reprogram my TCU. Wouldn't gain anything. It'll be nice to see again when everything is setup properly with the bigger pully and a tight belt. What gear were you in when you did your pulls? I did mine in 3rd gear in my WRX.
#425
it would be better if he did his pulls in 2nd with the manual button so that they start at 2500ish rpms for the next set.
I think you are missreading his torque. He has 7 lbs of boost at 1st which drops to 5.5lbs as his rpms go up...that is why his torque is higher earlier than later in his current plots. From his plots it's obvious the engine isn't dropping torque until up somewhere around 5700 rpms. |
#426
motor is in the cradle. Everything is ready to go.... waiting on cams
Tom |
#427
boost is still dropping off now with the 12 lb pulley. When you go WOT the boost goes to 12psi and then from 3000 to redline it slowly falls to 9.5psi. I think the slip is on the blower not the crank though. I need to fix my power steering and then fool around with the belts to get them to hold well enough to keep the boost from dropping off.
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#428
lol, I bet with power steering fluid all over the place.
****Deleted****
Kevin Thomas 1997 2.2ltr Subaru Impreza Outback Sport Wagon (AWD/Auto) 13.03@100mph 1989 2.7ltr Subaru XT6 (AWD/Auto) 15.912@85.93mph 1996 3.3ltr SVX (AWD/Auto) 15.070@91.38mph ***R.I.P*** 2010 RAV4 AWD Sport (13.717 @ 99.19mph ) 2015 Honda Fit LX CVT (15.2 @ 90mph) |
#430
#431
we could run a cog belt and never worry about belt slip. BUT like you said, machining them would be a nightmare... thats more or less a small/big block thing to do
Any word on a tracking # for those cams?? Tom |
#432
well my package has been in the mail for almost 2 weeks now... Mike got his 2 days ago and I still don't have a tracking # or anything... Totally ****ing me up right now
Tom |
#433
FINALLY!!!! I ended up googling the cam grinders and got their phone #. Ken was easy to give me a tracking # and I found out the adress on the package was wrong and they were holding them at the local UPS center. Drove down and got them.... now its time to get my motor runnin.....head off to the highway... lookin for.... well u know what I mean
Tom |
#434
welll got it running yesterday. Drove down to my fols house for the weekend. I gotta run by the PO and then its off to driving for a while to put some break in miles on her...
Tom |
#435
Nice! Any initial impressions?
-Bill
