Stainless steel brake HARD lines
Does anyone know if it's possible to get stainless steel hard lines? I need to replace one of my front lines, and I should re-do the hack job replacement some previous owner did of my rear lines. Factory replacements are actually not expensive at all, but it there are stainless available I'd like to pick up some and bend them to shape.
Re: Stainless steel brake HARD lines
Why not try coating the stock lines?
1992 Liquid Silver/Black LSL LeveL10 Stage 3 Trans and associated stuff |
I though the stock lines WERE coated? Mine are...
'92 Liquid Silver SVX - Drilled&Slotted Rotors/Canadian OEM Seat Warmers/JDM Folding Mirrors/JDM Clear Corners/Euro Glass Headlights/Euro Headlight Level Adjustment/Euro Shifter Assembly/ECUTune Chip V.1/GARAGE QUEEN! |
Yes, they're rubber coated up about an inch before they end, but I have to replace a few of them, and I like stainless.
Oh, well my replacement lines weren't coated because I just bought lenghts of line and made my own. They were galvanized though. I am thinking the ribber is GREAT as long as nothing gets underneath it, then all it does is hold moisture against the lines.
I was reffering to more or less buying bare lines and painting them with engine paint and clear coat. Stainless anything isnt cheap
Huzzah! Jegs sells straight lengths from 8-72" for $9-$30. What size lines and fittings does the SVX use?
http://www.jegs.com/p/JEGS/758028/10002/-1
