Old 05-31-2005, 05:37 PM
godspeed94
gas tank removal
Can anybody help me with instructions on removing the gas tank.....I have to replace the fuel line that goes from under the car up to the fuel pump.
thanks
Old 05-31-2005, 06:38 PM
immortal_suby's Avatar
Thread Killah
Check my locker. I scanned the service manual pages for it in there.
Locker Link
2015 BRZ Limited 6MT
Old 04-24-2008, 05:34 PM
Tiamat-red's Avatar
Tiamat-red Tiamat-red is offline
Following the path of the beam
Do you still have this?
I need to replace the darn hardlines...
Matt!
92 Ebony LS-L "Jabberwerwok" Now includes 1 *free "Wheeeeeee" per ride!
83 Honda Magna v45 "Grendel"
*Free after mail in rebate
Old 04-24-2008, 06:26 PM
The short version? Remove the entire back end of the car. Diff, axles, suspension links, subframe, the works.
It may be possible to get at the lines you need to fix through the access panel under the rear seat.
If you do end up dropping the tank, check the brake lines that are back there. It may be good preventative maintenance to replace them while they're accessible.
Old 04-24-2008, 07:19 PM
Thread Killah
Oops, I deleted them from my locker a while ago, and my scanner has long been thrown out. But later tonight I'll dig out the fsm and take a picture of these pages and post it here.
Locker Link
Old 04-24-2008, 07:40 PM
Thread Killah
Locker Link
Old 04-25-2008, 02:56 AM
JaySVX's Avatar
JaySVX JaySVX is offline
Don't be fooled, the guy in the diagram may be smiling while doing it, but i doubt you will be. This is significantly easier on a lift, doing it on jack stands would be a huge pain.
So there's a burst in the hard line between the tank and the front? Can you relieve the pressure on it, find the hole and repair the hole? If so, that sounds significantly easier.
*No SVX at the moment...*
1987 Winnebago Elandan 35'
2001 Yamaha Roadstar 1600
Old 04-25-2008, 06:27 AM
Tiamat-red's Avatar
Yes, I'm pretty sure I found the hole. Just not quite sure it's the only one.
It's one of the hard lines just outside the tank and before the hose.
I'm sure I WILL try patching the hole first, "just so I can drive it to the shop", and then drive around like that for several months at least.
What I'm wondering though is, is it possible for the tank to break or crack where the lines pass through?
Matt!
Old 04-25-2008, 06:31 AM
Tiamat-red's Avatar
OH! And thanks for the scans!
Even though they confirmed my worst 'working on the car on the weekend' fear...
Matt!
Old 04-25-2008, 06:49 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
... What I'm wondering though is, is it possible for the tank to break or crack where the lines pass through?
The lines don't pass through the tank, but rather through the lid. You should be perfectly safe there.
If you remove the inspection hatch, you can see this.
Old 04-25-2008, 05:10 PM
Tiamat-red's Avatar
Sweet, ok, I'll have to see what I can do this weekend.
Thanks guys!
Matt!
