Locks frozen inside and out??
The other day I went to pick up a friend to take her to the Airport. However when she went to get in, the passenger door wouldnt open. I tried to unlock it from the inside but the lock was just frozen in place and would not lift up. Same as the outside, it just wouldnt budge. The driver side doesent seem to have this problem only the passenger. I tried De-icer in the outside lock with no luck. Does anyone know why I cant get this unlcoked and if there is a fix, because its no fun having to load everyone through the driver side
-92 Ebony LSL, complete with all the problems -New self paint job; charcol metallic silver -4.44 tranny, Nicknamed the SexVX : ) |
Re: Locks frozen inside and out??
It sounds like the door lock actuator seized up. This is not all that uncommon. You'll need a new one for that door.
Or just pull it out completely and live without power locks. I had the same thing happen when I bought my car, I could only open the pass door by pulling upwards on the lock from the inside while someone opened the door from the outside.
Actually it warmed up a lil today and the lock just came up with ease. So that must mean its frozen right? Or could it still be an actuator problem? I mean the power lock works on the driver door but doesnt work for the passenger door, and i have no clue how to replace the actuator, I looked for it once but had no clue what I was looking at. I was going to take my panel off and lube everything with white lithium grease the next warm day, hopefully that can help. Any other suggestions appreciated!!
If it works in mild weather it indicates to me a frozen mechanical piece. Lock de-icer washes away the lubricant in the lock mechanism (tumblers). It is also pretty much confined to the key area. I suggest a little spray of rust check into the key slot. This will drive out the moisture and lubricate it.
The problem of the inside lock button not moving won't be affected by this. It should move even if the tumbler is frozen, so is a separate issue. If you can get at the mechanism inside the door the first thing I'd do is pray all the mechanical bits with the rust check as well. Especially between pieces. It will work it's way in driving out the moisture and lubricating as it goes.
There's a little rubber boot on the actuator arm and when it gets old, small amounts of rain water can seep inside the motor box. It builds up gradually over time. When that water freezes it will stop the actuator from moving.
Even when it's not frozen, water in the actuator can cause intermittant problems. Sometimes the actuator can stop half way between open and closed, which jams the locks. I've opened mine up a few times, drained it, and applied WD40. I've been thinking about drilling a little drain hole at the bottom. But I guess a better idea would be to find a replacement for the old rubber boot that seals properly.
