Engine Oil
I have been lurking NASIOC a bit lately, and I keep coming across Shell Rotella T6 5w40 as a recommendation. Any thoughts on whether it might be good in an EG33?
Re: Engine Oil
http://motoroilbible.com/data-comparisons-combined.pdf
Are you after an oil that won't be too thick at lower temps (due to the tight engine passages) but will still hold up to Florida heat? If so, 5W40 might be a good idea. It looks like Redline is the best choice but it is probably much more expensive. However, with that HTHS number, I would feel comfortable going to a much longer OCI and especially if you go with the Bosch Premium oversized oil filter. If going with extended OCIs you might also want to switch to an AC Delco air filter which rated out as the best at filtration. That will help keep crap out of your engine. Redline, Amsoil and Mobil 1 are consistently rated the highest.
Re: Engine Oil
T6 5W40 here.
Re: Engine Oil
Yes, Mr blueprinted motor. But should I use it in a stock motor with stock clearances?
Re: Engine Oil
I've been pondering the Rotella as well as I know the WRX and STI guys seem to love it. |
Re: Engine Oil
The above, below, and behind are a little different, of course.
Re: Engine Oil
My 6-speed car sees high revs quite a bit, and sustained 3500+ revs on highway trips as well (doing 70-80). So I'd like to make sure it's good to handle that.
Re: Engine Oil
As far as Mobil 1 is concerned, it has always been a highly regarded oil. I have never heard a good reason as to why people think it is flawed other than correlation to an engine failure which does not equal causation. Now, it is true that all synthetics, M1 included used to be much thinner. For engines that need thicker oils, that could have been a problem. But that is in the past now and is no longer the case. I would choose M1 over Rotella but Rotella is a decent oil too. Rotella is made by SOPUS which does not have as god a reputation as XOM, in general. Ironically, my mechanic now carries both M1 and Rotella. He used to just carry Rotella but now offers both. Whatever way you go, 5W40 synthetic is probably a good idea in Florida. What is your OCI now? What oil filter and what air filter are you using? I can post an air filter study to support the change to AC Delco. If you go with a high efficiency air filter and oil filter along with an oil with high HTHS, you really should be able to extend your oil changes and offset that extra cost.
Re: Engine Oil
I use Shell Rotella in the blue jug $18.00 a gallon at Wally World ( if this is the same stuff you speak of ) in my motorcycle and it is far better than any other oil I have used . Since the trany and engine share the same oil , the bike shifts very smooth.
