Old 11-30-2007, 10:59 AM
AlcyoneDaze's Avatar
AlcyoneDaze AlcyoneDaze is offline
<-- custom hood ornament
Send a message via AIM to AlcyoneDaze Send a message via Yahoo to AlcyoneDaze
4.11 swap - aftermath
Well, my mechanic buttoned up the car yesterday and I took her out driving. Everything seems fine, no binding around corners, FIRM shifts compared to my slipping stockbox, and ACCELERATION
(your money order is on its way Tom)
Seems I'm having one issue: when letting hammering the gas or letting off the gas at highway speeds, there is a loud rattle coming from the center of the car. Im HOPING its just loose exhaust shields... thoughts?
1992 Pearl White/Black Onyx Subaru Alcyone SVX LS-L
Donating Forum Member In Good Standing
JDM 4.11 Geared Transmission
JDM 'ALCYONE' Rear Panel
JDM 'BOXER' Eingngine Cover
JDM 'SVX' Hood Badge
L-Edition Suede Rear Seats
Old 11-30-2007, 11:03 AM
that or a bed resonator
Old 11-30-2007, 11:14 AM
Its a REALLY noticeable scraping/grinding rattle, if it helps, it also does it as soon as I turn the key to start her up
Old 11-30-2007, 11:18 AM
crazyhorse's Avatar
242,000 mi on oem trans
If not the heat shields it COULD be the Torque Converter bolts being loose. They make ugly noises. They're also not a huge deal to check.
"42"
Current Stable By Age:
Old 11-30-2007, 11:20 AM
how should i got about checking them? pictures or diagrams would help.
my mechanic reused the torque convertor from the 4.11 trans... is that going to be a problem down the road? or will it be fine if I don't romp the car
Old 11-30-2007, 02:21 PM
or a bad flex plate... i would check the bolts though
Old 12-03-2007, 02:52 PM
This will most probably lead to transmission overheating when the weather is hot.
You should ONLY use SVX torque converters, or 4,44 torque converters, and THOSE only with 4.44 transmissions.
