Old 04-13-2012, 12:52 AM
Ankh599's Avatar
Ankh599 Ankh599 is offline
Ocassionally check engine light comes on engine runs bad
I have a '93 with 123k miles and ocassionally my check engine light comes on and the car idles bad. If I'm at a stop with the car in drive or park it will idle bad and cut off. Then in about 30 seconds it will stop and the check engine light goes off.
I've had the Mass Flow cleaned as well as my IAv and the problem still remains. Anyone know what can it be???
Old 04-13-2012, 01:41 AM
Re: Ocassionally check engine light comes on engine runs bad
Check the code. If the check engine light comes on, then the ECU has stored a code. There are instructions in this document: http://www.subaru-svx.net/forum/atta...7&d=1330285331
Old 04-13-2012, 09:05 AM
Green1995SVX's Avatar
As he said, check the code(s) and report back to us with what you find.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 04-13-2012, 01:07 PM
kwren's Avatar
kwren kwren is offline
MAF?...smells like it!
Keith
Old 04-14-2012, 11:19 AM
Ankh599's Avatar
Thanks for the guide, I'm on it and will respond back today.
Old 04-14-2012, 10:59 PM
Ankh599's Avatar
Checked on the price of a MAF...over $200. Does anyone know of a cheaper price.
Also, cleaned the MAF again, changed the fuel filter and then did the Seafoam process...AND this car is running like brand new. What a PUNCH when you floor it. BUT the check engine light still comes on and it runs bad.
Old 04-14-2012, 11:04 PM
Also, cleaned the MAF again, then did the Seafoam process...AND this car is running like brand new. What a PUNCH when you floor it. BUT the check engine light still comes on and it runs bad.
Did you actually check the codes?
Also, it is highly possible that the solder joints in the MAF have gone bad. Many people have had success opening them up and resoldering. The other option is to buy a used MAF typically. Or fork out the money for a new one.
Old 04-15-2012, 08:59 AM
Ankh599's Avatar
Just found out how and checked the codes.
32 - O2 Sensor RH
31 - Throttle Sensor (Been Changed)
37 - O2 Sensor LH
24 - By Pass Air Control Solenoid Valve
23 - Air Flow Sensor
Looks like I'm spending a good part of my day under the hood. Hopefully one of these is likely the issue.
Then I can concentrate on the 5 speed swap.
Old 04-15-2012, 10:46 AM
Start with the lowest number code first, replace/fix and clear the codes. You may want to also think about clearing the codes as they could be stored from the past. Then wait for the light to come on again and recheck.
Old 04-15-2012, 11:40 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Check all your vacuum hoses for disconnections or cracks.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-20-2012, 08:10 AM
Ankh599's Avatar
It was the Mass Air Flow Sensor. Yeah, but now the damn thing cuts off when you put it in gear. My dad said back in the day it was the pollution pump, now if your car does that it's the O2 Sensor. Which my car showed were bad. So I'm trying that next.
Old 04-20-2012, 08:35 AM
you may want to do more checking before you run out and replace the o2 sensors. if you have a voltmeter you can do quite a bit of checking to see what the car actually needs before replacing parts. did you replace the maf? is the new tps calibrated correctly? do the o2 sensors respond to a forced lean or rich condition?
Current Stable:
1992 SVX
1979 K5 Blazer Cheyenne
1967 Chevy C20
1953 Chevy 210
1969 Plymouth Satellite
1949 Chevy Thriftmaster
1959 Chevy Apache
1951 Chevy Stepside
1969 Chevy Camper Special
1978 Ford F150 w/ stroked 460
1986 Volvo 740 turbo wagon
1999 GMC 2500 Creep Van
1994 Impreza Outback
Old 04-20-2012, 07:50 PM
Ankh599's Avatar
The MAF was definitely the problem. The new situation when I'm in drive or reverse and mash the brake the damn thing cuts off. Turns out it was the transmission. So my trans is completely gone!
But I was able to get all the '98 Legacy parts to do the swap to a 5 speed. Just waiting for them to arrive and my mechanic to come back from his honeymoon.
Old 04-26-2012, 12:38 PM
BackWoodsBob BackWoodsBob is offline
Can anyone tell me what colors the error diagnostic test plug uses?
I have a swapped car and need to run the diagnostic but the harness didn't' come with the plug, so I'm stuck using wires .
Old 04-27-2012, 08:45 AM
Tapani Tapani is offline
Down load all 1992 US spec manuals from here:
http://phantomotaku.com/SVX/
Tapani
