Here we go again - 'puter problem - dead mouse.
Once again, I come on bended knee, to seek guidance from the younger generation. From one session to the next, my GF's mouse cursor froze. The machine was left "on" overnight, as it's always run on A/C power at home. I've been to 'puter help sites to no avail, & buying a new mouse ain't the issue; it's just that I'd like to know WHY this problem exists.
Cast of characters: One Dell Laptop with Windows Vista, & one Logitech wireless mouse; both about 5 years old. NOTE: I tried the mouse on MY HP desktop, & it works just fine! What I've done so far - the usual stuff - Reboot 100 times, run defrag, run registry "fix". Re-set mouse button, un-plug transmitter umteen times, switched USB ports, de-installed driver, & re-installed. The computer tools thingy says, "Working properly" (LIAR!!) The cursor works fine using the laptop's touch pad, but still stays locked from the mouse. No new wireless devices were added to, or taken from the room where the laptop is used. The ONLY thing that appears a bit goofy to me, is when I look at the screen that shows devices in use, it lists the mouse as a Synaptics P5/2 which it ain't - it's a Labtec. But it's probably said that since day one, as we've never had to tinker with anything ever. If the answer is "buy new mouse", no sweat, but the mystery remains, & will drive me even crazier. Ron, the un-geek.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. Last edited by Ron Mummert; 02-13-2012 at 03:00 PM. |
Re: Here we go again - 'puter problem - dead mouse.
No computer geek here (and I use a Mac with a wired mouse besides), but I'd suggest going to system preferences/set-up, delete the "installed" mouse and re-introduce the one you want to use.
dcb |
Do you have a different mouse you can try on the laptop? Perhaps the one from the desktop? Quote:
Stupid as this sounds... I was told to turn off the computer . Bring the mouse into another room, turn it on and then go get the mouse, I have never tried it. A computer geek told me this. They cant be in the same room . Try it can't hurt.
Also told me to try different USB ports.. I see you did that. Good luck!!!! |
Talked with Ron a bit ago.
In the control panel under "mice and pointing devices" we looked under connected devices, hardware, and even in the Device Manager. His Logitech mouse does not show up anywhere. The only thing there is his touch pad (which the computer says is working properly) He said he uninstalled the driver and reinstalled it, but since he did not have the original disc and did not download it from the internet or update the driver, I am not sure it was actually reinstalled., so the computer couldn't see it. Plugging it in to his new desktop it worked fine instantly. Somehow there were compatible drivers installed or they weren't needed. I wanted him to do a System Restore, but on this 5-year-old computer, there were no prior restore points to go to. He could create one for today, but that's it. I don't understand this; usually computers automatically create system checkpoints at various intervals or you can create them manually. .
[QUOTE=Conn SVX;697063]Stupid as this sounds... I was told to turn off the computer . Bring the mouse into another room, turn it on and then go get the mouse, I have never tried it. A computer geek told me this. They cant be in the same room . Try it can't hurt.
Your geek friends are probable still laughing over this one, Conn. The only logic I can see here is if there's some kinda' RF interference that has somehow wormed its way into the mouseworks and.................Nah. (but I tried it anyway) Thanks, Ron.
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. |
Update. Correction - not that it matters much but, it's a Logitech mouse, not Labtec. My speakers are Labtec, so it's easy to see why I'm SO confused.
Thanks to all so far - In the meantime "Johnny on-the-spot" (SVXcess) & I have beat this to death via telephone. I've been enlightened to the fact that it's the "internal" mouse that's being recognized. Nonetheless, for the last 5 years, both mice lived in perfect harmony 'til, for no apparent reason, the ghost gave up. It's been a long time since I connected an external mouse, & don't remember the process. If the driver was loaded from a disk, so be it. Anyway, the disk is buried "somewhere" in the house. As I mentioned, my desktop, which is fairly new, & running Windows 7, seemed to accept the wireless mouse simply by plugging in to a USB port. No other set-up required. I'm not going to try my wired mouse in her machine because it's cord "tacked" on to my desk, & wound around enough other wires to make the removal attempt ugly. So.... My GF has informed me that a new Wally-World mouse is on its way home tonight. We'll start from scratch again. But the real "WHY" question is still unsolved. Humbly, Ron. PS to John - The Logitech link you sent me wouldn't download "unless" I went to their site & performed some more monkey business, at which point I said " #@$!!&&". Here's lookin' forward to new shiny mousie!
Good s**t happened. 69 was worth the wait. '92 stock semi-pristine ebony - 160K '96 Grand Caravan - 240K '01 Miata SE - 79K '07 Chrysler Pacifica - 60k - future money pit. Last edited by Ron Mummert; 02-13-2012 at 02:32 PM. |
No, no, no! You need to lay your computer and mouse at the feet of a virgin under the light of the full moon at, precisely, 3:33.33 am, rotate it 7 times counterclockwise, then 14 times clockwise. You must, then, dance the ancient dance of the techno geek tribe for 21 minutes. Then, beat the hell out of it with a hammer and, if the virgin is of age, well...
Sorry, it's getting late. |
[/I] I skipped the virgin thing (none down here in Virginny), & went directly to the hammer. Still no luck, but I feel better. Ron.
My Intellimouse Explorer gave up at 5 years.
It would work intermittently, sometimes for even days at a time, but for a few months I was going mad because I wasn't quite sure if my 3 year old rechargeable batteries were bad or if it was the mouse itself. I had no other use for rechargeable AAs so I had no other option than to buy something; new batteries. The problem persisted. Mouse was later replaced and bid a sad farewell. Interestingly, of these newer batteries which I have not even been using but sparingly, one recently ruptured, emptying some of it's bubbling contents into the device it was powering. What's more interesting is the newer batteries were Japanese, while the ones that I have used for over 3 years were made in China. Dun dun dunnnnnn! In somewhat related news, the Logitech mouse I bought as the replacement absolutely will not work if a specific game controller is plugged in at the same time.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 02-13-2012 at 11:50 PM. |
You mentioned that? I must be half-asleep this entire week or something.
Does the speakers work through the same port as the one you use for the mouse? I have my Logitech G700 here and I'm just trying to remember everything weird I had to do to get it to work. Does your M315 have a power switch on the bottom?
http://i840.photobucket.com/albums/z...93705d9zzz.png |
Windows Vista is the problem - i also have the same POS OS.
I cant wait to get a new desktop, although with my luck, Windows 8 will have massive amounts of fail, also.
Try turning off the touchpad? Sometimes a conflict could cause the touchpad and external mouse to fight each other. This could be done by doing FN + F5 etc (just make sure the key is labled as touchpad. It may not be F5)
