Old 01-31-2011, 08:20 AM
VICSVX's Avatar
VICSVX VICSVX is offline
Never Forget
5sp ??
FINALly put a 5 speed in my car but now Idk if it drives right? I have a 99 impreza trans with matchig diff 3.90 and not sure how hard 1st and 2nd pull? ANYone know? Seems sluggish to me but could be just the gearing or the trans is bad? Drives fine other then that
VICSVX
94 SVX L AWD Conversion Barcelona Red First car and now being restored, 215xxx
Old 01-31-2011, 10:24 AM
Wikedjuggalo's Avatar
Rebuilding
Re: 5sp ??
Can you explain a little bit more?
Old 01-31-2011, 01:22 PM
VICSVX's Avatar
Never Forget
Re: 5sp ??
In 1st and 2nd, the RPMs go high but the speed barely increases...it shifts fine but not sure how its suppose to drive. Idk if that makes sense lol it doesn't pull like i thought it would I guess....
VICSVX
Old 01-31-2011, 01:38 PM
Re: 5sp ??
Did you put a new clutch in? what did you use? Sounds more like a badly slipping clutch. Might be out of adjustment as well...
Old 01-31-2011, 03:15 PM
Rebuilding
Re: 5sp ??
How high rpms are we talking and what speeds. it does sound clutch related
Old 01-31-2011, 08:12 PM
VICSVX's Avatar
Never Forget
Re: 5sp ??
Exactly what I thought so I put a new clutch in on Sat. It's an ACT and the flywheel looked perfect. SO Idk what the problem is. Pedal feels fine....
VICSVX
Old 01-31-2011, 08:16 PM
VICSVX's Avatar
Never Forget
Re: 5sp ??
Also put a new throw-out bearing and pressure plate in too....
VICSVX
Old 01-31-2011, 10:32 PM
oab_au oab_au is offline
Re: 5sp ??
It may not have any clearance between the throw out and the pressure plate. Check the throw out fork to see if there is some freeplay.
One Arm Bloke.
Tell it like it is!
Old 02-02-2011, 01:27 PM
Re: 5sp ??
Did you get the flywheel cut/turned?
Old 02-03-2011, 11:12 AM
VICSVX's Avatar
Never Forget
Re: 5sp ??
What do you mean by checking free play between throug-out bearing and flywheel?
ANd no I didn't get the flywheel tuned...
VICSVX
Old 02-03-2011, 11:24 AM
Bonestock's Avatar
Bonestock Bonestock is offline
Nürburgring Warrior!
Re: 5sp ??
2010 Subaru WRX
1992 SVX LS-L 89k miles-SOLD!
KTM 250sx MX bike aka "Killer Pumpkin"
Old 02-04-2011, 07:59 PM
VICSVX's Avatar
Never Forget
Re: 5sp ??
i havent...
VICSVX
Old 02-04-2011, 08:03 PM
Re: 5sp ??
Originally Posted by Bonestock View Post
Has anyone looked into using the Legacy 6MT? It has to be cheaper than the STi's 6MT.
Not exactly the right place to post this bro.
Old 02-04-2011, 08:14 PM
Bonestock's Avatar
Re: 5sp ??
2010 Subaru WRX
Old 02-04-2011, 08:18 PM
Re: 5sp ??
No dude, he has a specific problem related to a 5-speed that's already in his car.
