Rear diff side bearing preload?
How do you guys adjust the rear diff carrier side bearing preload? I know the shims are swapped, but how much preload?
The manual gives a formula which uses a lot of different figures stamped in the OEM parts, but I'm installing a Quaife carrier with no exact measures. The shims which were in the OEM assembly give practically a zero preload.I checked with out the crown wheel and no shaft seals. -Zero turning resistance. The more recent R160s have the same adjustment as the front bearings in the 4EAT - turning the bearing retainers. The manual calls for half a tooth preload - with 18 teeth this is 1/36th of a turn.... 1mm thread pitch results in approximately 0.03mm preload. Any comments? Thanks, Tapani |
Re: Rear diff side bearing preload?
If I were you I'd call Quaife and ask.
Well, their instruction is to go with the OEM recommendation
Same thing with the Detroit Truetracs I had in my Range Rover. Adjustment as per manual. There's something weird in the manual also.... the pinion (only) rotation resistance is given as newtons (force) using a spring scale and pulling from the drive shaft bolt hole.. the additional resistance (increase) from the crown wheel tooth contact + side bearing preload is given as a torque. Must be a error in the latter figure. Tapani |
