Front Main Seal, Anyone Tackle?
I'm wondering what's involved with replacing the front main seal? I have searched but no one
seems to say much about it which leads me to two conclusion, 1. No one has done it. or 2. It's really easy and not worth writing about. It looks like it's just inside the oil pump on the diagrams, should I plan oin replacing the oil pump while I have it all apart? Thnks, Blue |
Re: Front Main Seal, Anyone Tackle?
I change it (the front crankshat seal) out on every timing belt replacement,
(unless the owner is on a VERY strict budget.) Part #s are here at post #8. http://www.subaru-svx.net/forum/showthread.php?t=45206
Well i was going to do it tomorrow but sems I have a worse leak in my valve covers now so its put off til next weekend Ill let you know how it goes though
I'll be waiting for your response, thank you. Sorry to hear about your other leak, I have more leaks myself but was thinking of tackling this one first.
Thanks for the Part# svxfiles |
Since the front main seal is installed on the oil pump, which is pretty easy to remove, I just pull the pump off to replace the seal. That way I don't have to worry about damaging anything when I remove the old seal.
What are the issues in removing the crank sprocket? Does the oil pan need to be removed to access the oil seal & oil O ring?
What are the safe methods to remove the sprocket?
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
Yes, its very safe... First if your crankshaft sprocket has issues, its better just to remove it. It should just pull off. Or gently be pried off. No. The oil pan only needs to be removed to replace the oil pan gasket, fix a leak, etc.. The oil seal/front main seal and O-ring can be replaced after you remove the oil pump. Make sure that you tighten the screws on the back of the oil pump.
