What size tire?
What tire would be best for this rim on the stock suspension so I don't rub?
Info here. http://www.discounttiredirect.com/di...w=7&vid=006494
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress Last edited by redlightningsvx; 06-09-2009 at 07:45 PM. |
Re: What size tire?
225/45/17 would fit nicely, retaining stock diameter.
Re: What size tire?
I'm running 225/45-17's on my ADR 17x7 48mm offset wheels.
1997 Boudreaux LSi 1994 SVX LSi(SOLD) Kool Blue air filter, 4500k HID's, airbox mod, Hella horns, WRX 6 disc stereo, Infinity Reference and Clarion Pro Audio speakers, Infinity basslink sub, ECUtune Stage 1v5, ECUtune TCU, Power mode mod, Mad muffler mod v1.3 |
Re: What size tire?
Thanks................
Re: What size tire?
Will 225 60 16 tires rub? I have some all season take-offs from my outback that I would like to mount on my SVX winter rims until I can afford a new set of winter shoes for the SVX.
Thanks, Christian
Christian- 96 SVX Lsi #821, Bordeaux Pearl, 4.44 98 Legacy Trans, Trans Resistor Mod, Dakota Digital Trans Temp Gauge on A-Pillar Pod (awesome), B&M Trans Cooler in Driver's Wheel Well, External Spin-on Trans Filter, Synthetic Fluids in Trans and Diffs, 17x7.5 Primax 695 Rims, Alcyone Rear Panel, Svxfiles' 5000 k HIDs, Clear Headlights, "BOXER6" License Plate, Hard Wired Radar Detector, 94 Power Up Window Switch, Motor Resealed, new Coil Packs, new NGK Iridium Plugs, PVC Valve, Drilled and Slotted Rotors, Gloss Black Calipers and Rotors, EBC Greenstuff Pads, SS Brake Lines, Superb TomsSVX Cat Back Exhaust... SS Resonator, Flowmaster 80 Muffler, Magnaflow Quad SS Tips, Poly Swaybar Bushings, Endlink Mod, Rear Subframe Bushing Mod. Feels great and sounds even better. Thanks to AWD, LLC. 2003 Outback llb H6 3.0 Titanium Pearl- "BOXERR" Mostly Stock 1995 Bmw 325i Conv. Calypso Red- "RBOXER" Modest Mods 2004 Sea Doo Sportster 4-tec 15' Jet Boat, 1494cc, 1454#, 155 HP= <10#/HP Stock |
Re: What size tire?
It will be close. On SVX rims you're asking? it might rub on the plastic fender "mud guard" or whatever it's called but won't rub on anything else. And even so, unless you have 200+lbs in the trunk or go over big bumbs, it still might not rub at all.. Might as well give it a shot and see, or at least that's what I would do.
Re: What size tire?
I bought a set of 17" alloys from an RX7 with ET of 50 mm.
I am planning to fit 235/45 Y17 on them. Will this combination fit? It should be 5 mm wider inside and 15 mm outside. Diameter is the same as original. Any reccommandation regarding tyre brand/type? |
Re: What size tire?
Should be just peachy. What kind of tire are you looking for? Ultimate grip, touring, etc?
Re: What size tire?
The SVX is my daily driver. For excessive fun I have a Lotus Turbo Esprit.
I think I am looking for a set of tires, that gives neutral/direct steering, with good braking and wet performance. Noise and rolling resistance is less important. I would say 60% sport and 40% touring. I have been looking at: Falken ZE912 Bridgestone RE050 Pirelli (P7, Zero) Dunlop SP01 Hankook (K105, V12) |
Re: What size tire?
I've got 245/40zr17's on mine, with 8" wide rims.
HERE is a very handy tire size calculator that I often refer to. You'll find what sizes you can run that will measure the same diameter as stock, or find out how far off your speedo will be with another size tire.
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
