Old 10-31-2010, 07:24 AM
impeller23 impeller23 is offline
speedometer stopped working..
Hi ,
My speedometer stopped working and the " Engine Check Light" came on..Does this relate to a speed sensor ? If yes, what causes this problem and how expensive is a vehicle speed sensor for 1992 SVX?
Thanks,
I.
Old 10-31-2010, 09:21 AM
NeedForSpeed NeedForSpeed is offline
Re: speedometer stopped working..
Originally Posted by impeller23 View Post
Hi ,
Thanks,
I.
Likely, the speed sensor on the passenger side of the transmission, on the diff housing, has failed. I don't know the cost, someone will probably provide a link for that. Not too difficult to change.
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 10-31-2010, 10:01 AM
Does the power light flash at startup? That's what mine did when the speed sensor failed in my car. Luckily I had an extra one attached to the 6-speed I bought that arrived the week before. I'm told the sensor is super expensive from Subaru. Best to pick one up from a parting out thread.
Old 10-31-2010, 11:47 AM
Thank you very much, guys!
Old 10-31-2010, 01:22 PM
michael's Avatar
michael michael is offline
What Potholes ???
If it's the sensor, you're lucky. If it's the gear that drives the sensor, you're in for a surprise. To check the operation of the drive gear you need to pull the sensor. Insert a flathead screwdriver where the sensor was in the notch for the sensor. Put a mark on the handle and drive a few feet. If it rotates, it's functioning, if not you have to pull the diff to replace the $2 part. The sensor is located right by the diff dipstick. Good luck, I had both go bad and it cost around $500 to repair. A malfunction with this sensor will mess up all kinds of things from your fans to your cruise control, wipers and awd system.
Wanted: Steering Wheel
Old 10-31-2010, 01:26 PM
cost me $4100. TH
