Finally picked up my 96 SVX. Temp gauge moves around a little.
There is a little road noise which I think might be the tires or it could be a wheel bearing. Not unexpected. Brakes seem solid. Once warm, tranny shifts almost imperceptibly. Pretty good news all around.
One thing I noticed when driving in hilly country (in 3rd on the climbs!) was that the temperature gauge moved a little. When climbing a hill it went up to around where the little thermometer bulb would be on the gauge decal. That's about 40-45% up. When going down the hill in 4th it would drop a little to about where the wavy water part of the decal is. I would say that's about 35-40% up. It doesn't move much but you can notice it moved. Is this normal or is it a sign that something needs to be checked or replaced? The outside temp was mid-70s. |
Re: Finally picked up my 96 SVX. Temp gauge moves around a little.
First change to a new Subaru thermostat, t-gasket, Subaru radiator cap, and new coolant.
Second, start saving for a head gasket job. Also make sure your radiator fans are working.
If the problem is just a bad thermostat and the temperature is not getting high, why worry about the head gasket?
Usually a fluctuating temp gauge indicates abnormal cooling system operation, and this paired with the fact that our cars are all about due for HG failures from age, and its a logical assumption.
OK, I get that head gaskets can fail with age, and I should be aware of it, but this may not be related. I guess a good question for me would be to ask how I can look for symptoms of an actual head gasket failure or, better yet, the beginnings of a leak. I don't see how temp fluctuations from cool to normal would indicate a head gasket problem.
Just wait, it will get progressively worse. I have a 96 Lsi and had the same issues two years ago. Temp. gauge would spike all the way up and then settle down to normal, and coolant would spill out of the overflow tank. Drove the car like this for two weeks, and nothing got better. Svxfiles tried stopleak and same results. He finally gave me the cheapest Head Gasket job anywhere. Runs awesome now. Thanks again Tom K!
While still in the normal, almost level range the ACTUAL water temperature could be as high as, say 260°f! (as I rember) The definative head gasket test on an SVX for me is to after replacing the rad cap, thermostat and gasket, pressure testing the system, checking the fans, to drive out to "HEADGASKET HILL". And while driving up this seven mile, 7° incline observe the actual water temperatures with a Subaru Select Monitor. If, on this drive the temperature spikes by the top of the hill/mountain, I know that the head gaskets are bad. I have posted actual readings regaurding "Dan The Man's" SVX, but do not have time right now to look up the pojst. Perhaps John can find them for us? John?
Keith Husky maniac, is it the 4 legged animal Husky you are crazy about? The dog? Last edited by kwren; 08-02-2010 at 11:39 PM. |
Well, I am getting it checked out by my mechanic today. Here's hoping that the thermostat is in there and stuck open.
I have to say that the car transmits road noise. On rough pavement it can get loud. Those concrete highway sections are noisy. It makes it tough to distinguish between road/tire noise and bearing noise. |
Have you checked to make sure all the tires are matching?
1991 SVX L JDM |
I hope it's just that your tires have a very aggressive tread. dcb |
They are directional tires, which tend to be a little noisy. And the noise level varies greatly depending on road surface. But, hey, it is a minor issue relative to the potential head gasket problem.
