crank
can i use a impact gun to get the crankshaft pulley off? I need to know right away. and thanks in advance for the help.
94 Subaru SVX FWD 51k 04 Mazda B4000 (work truck) |
Re: crank
Long break-over bar, socket and use the starter.
Re: crank
a impact wont get it off?
Re: crank
yes it will, but its just so much easier to use a socket on a large breaker bar and have a friend crank the ignition over while you hold the bar steady.
Mike 1992 SVX LS-L Pearl White 102,000 miles (Gone) 2005 Evolution 8 SSL Tarmac Black (new daily) 1995 Eclipse GSX Durango Copper Pearl (teh beast) 276awhp/280awtq @ 18psi (560's inj) 260awhp/260awtq @ 17psi (stock inj) |
Re: crank
Buzz it off with the impact
Re: crank
WTF? Dangerous? You mean like for the same dangerous the shop manual has in mind when it tells you to disconnect the neg terminal on the battery to change a tire dangerous? I use a 1/2" breaker bar thats 3 feet long, then I take the end of my floor jack (another 3foot section of steel tube) and put that over the breaker bar for extra leverage. 2 clicks from the starter with putting barely ANY resistance on the breaker bar and the bolt is a full turn loose. This should go without saying but when i was doing it the car was completely together. (A/C condenser, radiator, fans) and i had no room for an impact gun.
Re: crank
Hey, when its size five, and in RED, its important!
Re: crank
BTW I giggled a little when I read the title
Tom |
Re: crank
using the starter, though frightening the first time, is a fantastic and safe way to do it. I just slide a plastic pipe over the handle of the break-over and let it rest on the fender and crank away! Works like a flash.
Any other way is a waste of time... Please select the proper fender Keith |
Re: crank
Edit: I have read of someone successfully drilling 4 holes in a 2x4 to line up with the four holes in the pulley. Then they drilled a big hole (probably used a hole saw) in the middle for the socket to pass through. They inserted 4 bolts through the 2x4 and pulley, and used it to back up the pulley as they removed the bolt. MUCH SAFER! (though more time consuming)
Cam '92 Ls-L Dark Teal 11:1 CR ECUTUNE pistons ECUTUNE .256 duration intake/exhaust cams ECUTUNE STAGE 2AV1 ECU Z32 MAF/SR20DET injectors Balanced & Blueprinted Last edited by Cam; 03-20-2010 at 08:22 PM. |
Re: crank
Keith |
