ECUtune Stage 2v7 full kit
370cc Injectors w/pig tails
Z32 MAF w/pig tail 1992 ECU with Stage 2v7 Chip installed $520 SHIPPED anywhere
1992 SVX: JDM STI short geared 6-speed swap, COBB short shifter, slotted cross drilled rotors, Smallcar Clear headlight lenses, 1997 Grill. 1992 RHD WRX: EJ20G, 16G, Cusco Coilovers, Wilwood 4pot/2pot brakes, Defi Genome 60mm gauges, Exotic speed downpipe, 3.5" A'PEXi spec GT catback |
Re: ECUtune Stage 2v7 full kit
this is a great deal people! all together for my kit over 600 dollars!
94 Emerald LS w/ awd 4.44 swap 199xxx daily driver Stage 2 ECUTune chip, 370cc injectors, ECUTune valve body and TCU, solid rubber motor mounts from a forester, outlaw phenolic spacers, COBBTuning lightweight blue crank pulley, Bontragerworks 22mm rear sway bar & endlinks, StrongFlex poly front sway bar bushings, Powergrid adjustable front sway bar endlinks, 17" MOMO CORSE RPM wheels w/ Toyo Proxes4 225/45, drilled/slotted rotors f/r, stainless lines, ceramic pads, Blue silicone radiator hoses, power mode switch, gold jdm hood badge, 20% tint all around, Hella optilux xtreme yellow fog bulbs parts waiting to go on car: the rest of the strongflex polyurethane suspension bushing set |
I wish I knew what this stuff did so I'd know if I would benefit from it, lol.
The least expensive way is to use a LAN/ECUTune stage2,version7, or stage 2version(aggressive) along with a 370cc injector set, and a Z31 MAF. You need to have mors CONTROLLED fuel, and delivery to make more that 250 hp. Will this set up on its own make more HP? Yes, if you use the higher RPMs it allows, or have other mods that allow more fuel use for more power. I am about to add a stage2/aggressive, 370 injectors, Z31, LAN cams, and a worthy clutch to The Racer. If I did not have the Stage2/something something, the Z31, the 370cc injectors, the cams, would just cause the car to fall flat on its face, even with the headers and hi flow exhaust. So far the only other real choise is YT's stand alone.
Thanks for the information Tom. Maybe this is something I'd benefit from.. Might look into it soon if nobody buys it and after I get my exhaust done..
You should pick it up anyway great way to speed 520$!
It includes the whole ecu so u don't even need to crack yours open!
Although this is something I've been thinking about since I saw the post, I still have to finish this exhaust work, finally buy subwoofer boxes, and then maybe this. This entire setup is the same as a Hydra?
...no. it is not a standalone ECU. It is designed to run the Z32 MAF and injectors that are included. As far as I know, you cannot run your stock MAF with the ECUtune software. I would ask LAN any questions you have on this stuff.
Thanks for the info. I just might do that so I can find out if it will benifit me with my stock setup and custom intake and exhaust.
I believe it will give you more power. The maps in the ECU are tuned more aggressively and the bigger injectors will support more fuel delivery. I don't know how much it will improve a stock engine though. Wish I could help more.
Still have it, eh? I've got one last large payment this week. I'll shoot you a PM come Saturday.
Think Gamesy is grabbing it from me when I bring him a bumper. I'll let you guys know if anything changes
paid for it
will do still in the process of striiping down a 92 parts car
