Transmission question?
Hey guys,
I'm sure this has been discussed several times in the past, but will any other transmissions work in a 92 SVX with little or no modifications? I am getting ready to replace, or rebuild, my tranny AGAIN and am trying find out what other options I may have. Any advice is greatly appreciated. Thanks! Phil |
Some search tearms to try manual swap 4.11 4.44 numbers are gear sets.
86 GMC Jimmy Blue and Silver- R.I.P. 87 Integra RS ~228k miles R.I.P. 92 SVX LS-L Perly ~186k R.I.P. 89 240sx se red ~165k miles Gone and unknown 89 240sx se Black~185k R.I.P. 85 Toyota pickup ~205k R.I.P. 85 BMW 325e ~ Gone and unknown 85 Ford Mustang getting engine swap now! 05 Colorado ~108k Daily Driver |
I'm right in the middle of the same problem. I am shopping for a 1997 Outback transmission with a 4.44:1 final drive and a 4.44:1 limited slip rear differential to match. The gurus here have told me it is a direct, plug/play swap. You can also do the same with the 4.11:1 box and diff from non-outback Legacies, Foresters, Imprezas, etc. There may be some years that aren't 100% compatible (bolt patterns?). 1997 seems to be the sweet spot, and the prices I've found are reasonable - $500 - 800 for the trans and $150 - 300 for the rear diff.
svxpert has a 4:44 box and diff available with very low miles. I'm interested in that but will have a hard time getting to NJ to get it. Look him up. |
The OBS transmission will fit but the SVX torque coverter has to be changed over. I am told it is not a big deal. I'm even consider getting a new one.
I just got done swapping a 4.11 trans and rear diff. from a 1996 Legacy 2.5l sedan into my 92 svx. This swap was very basic. Everything fits perfectly. The wiring harness is a direct plug-n-play. Switching the LSD carrier from my SVX diff into the Legacy 4.11 housing was also very easy. You will find that your speedometer will read about 10% high after the swap. I do a lot of highway driving, and would not reccomend the 4.44 gears if you like to cruise at high speeds. With the 4.11 gears 3000 rpm is about 72 mph. The shifts are good and solid
The trans and diff were taken from the same wrecked car. The yard charged me $650 for the pair. I'm really impressed with how quick the car now feels. Looking forward to drag-racing it against my wife's 2005 Outback XT. Good luck with finding a transmission!
1992 SVX lsl - >111K, pearl, 4.44 gears, ECUtune stage 1 2005 Outback XT wagon - i love that turbo!!!! 2004 Dodge Ram 1500 Hemi Last edited by joeaxial; 10-02-2005 at 03:17 PM. |
Thanks joeaxial! I just found this transmission on ebay, any ideas if it would be compatible? Should I ask the seller any specific questions? I'm trying to learn, but am still not very familiar with transmissions specs.
http://cgi.ebay.com/ebaymotors/Autom...spagenameZWD1V Thanks again! Last edited by pcicco; 10-03-2005 at 09:59 PM. |
There are NO 2.5 "L"s in 1996 from the factory. The 2.5 engine 4EAT had 4.44 gears, and the "L" had a 2.2 engine, and 4.11 (4EAT) gears. With 4.44 gears, 3000 rpm on a car with stock tires, causes the car to travel 71.94 mph. On the same stock car 4.11 gears and 3000 rpm causes the car to travel at 77.76 mph. There is no more spedometer discrepancy with a 4.11, or a 4.44, than with the stock 3.545, as the speed sensor reads only the revolutions of the axle, as measures at the front differential.
