Old 10-18-2010, 09:05 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
Tranny problem
My mechanic swaped a Legacy Trans into my SVX. Runs great except for a ticking sound from the rear of the engine. I can hear it only when idling and not all the time. Sometimes it's consistant, sometimes it comes and goes. It also makes a clunking sound at start up. Is this the flexplate?
Old 10-18-2010, 09:26 PM
Green1995SVX's Avatar
Re: Tranny problem
It sounds like it could be the flexplate.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 10-19-2010, 08:20 AM
newkid17's Avatar
newkid17 newkid17 is offline
Send a message via AIM to newkid17 Send a message via Yahoo to newkid17
Re: Tranny problem
yes, the flexplate bolts need tightened, put a small amount of locktight on them. just enought to keep them in theree but not enough that you cant get them out the next time you need to.
my car did the same thing when i replaced the transmission.
Old 10-19-2010, 09:30 PM
dannmarr's Avatar
I work for my SVX
Re: Tranny problem
Does the trans need to be removed?
Old 10-19-2010, 09:43 PM
Re: Tranny problem
Yes.
Also make sure that both locating dowels are installed!
Old 10-20-2010, 01:51 PM
dannmarr's Avatar
I work for my SVX
Re: Tranny problem
Is it possible to pull the trans out just enough to check the flexplate? If it has to come out completly that = more $
Old 10-20-2010, 03:00 PM
Re: Tranny problem
It has to be at least about six inches back to remove the flexplate.
And while you are down there you might as well replace the rear main seal (WITH A SUBARU PART!) and reseal the access cover.
Did I mention the dowels?
Old 10-21-2010, 01:53 PM
dannmarr's Avatar
I work for my SVX
Re: Tranny problem
Can you please provide a write up in the procedure of removing the flexplate without removing the whole trans? My Mechanic isn't shure about doing it without removing the whole thing. Thanks!
Old 10-21-2010, 03:46 PM
Re: Tranny problem
Well, there's a delicate corneal inversion procedure... a multi-opti-pupil-optomy. But, in order to keep from damaging the eye sockets, they've got to go in through the rectum. Ain't no man going to take that route with me!
Old 10-21-2010, 03:48 PM
Re: Tranny problem
Yes, the transmission has to be compleatly removed from the engine, but after you have it out of the way you can access the flexplate.
Old 10-21-2010, 09:31 PM
newkid17's Avatar
Re: Tranny problem
too funny!!!
