idle trouble after deep puddle pass
Well, there was a deep puddle on the road which i passed at low speed..
SVX coughed for 2 minutes, then it died, but after immediate start i was not able to raise rpms over 3000 for next 15 minutes. Then the power came back to the car. Next day i replaced with new air filter which was looked like dirty deformed sponge.. Now i have the following problems: -No warming idle after cold start. It idle constantly at 1100rpm -High idle. 900rpm at 1,2,3,D 1100rpm on P -The car driven as usual, no engine power loss Thanks for help
Subaru SVX LSi `95 |
Re: idle trouble after deep puddle pass
Clean your maf sensor
what would cause the idle to still be high (1500 rpms) even after car is fully warmed up. No Codes, TPS set to 0.48 volts, 800 rpms idle on select monitor. This occurs randomly, not every time, but more often than not. Also several times the idle went up on its own in park with no one in the car. From 750-800 rpms to 1100rpms. Its the weirdest thing. This has been occuring for the past 1000 miles at least, but no codes, and car runs strong as a bull. All new plugs, coils, vacuum hoses, knock sensors, just about the whole kitchen sink replaced.
1995 POLO LSI 76K MILES SOLD |
Thanks Icing, I was thinking of that myself. I will replace it and see if that cures it.
The idle control valve under the throttle body can also randomly do this. If you have it off its easy to clean. Just mark the position of the motor on the end, take it off, spray in the chamber with some non-chlorinated brake cleaner, and rotate the shaft back and forth a few times, and dump brake cleaner out. When you put the motor back on, the valve should snap back into the correct position, and install the motor in the same position it came off in(should have marked it earlier, or you can see where the washers were).
'92 SVX LS Pearl White - 6mt |
Thanks,
clean with Carbcleaner or Wd-40 or whats better? And dry after?
Pick up some CRC Mass Airflow Sensor Cleaner. Should be able to get it ant Advance Auto, Auto Zone, or Amazon.com.
Spray 10 to 15 spurts of the cleaner onto the wire or plate. Don't scrub the parts; you may break the wire or damage the plate. Allow the MAF sensor to dry completely before reinstalling it in the air duct. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 03-27-2013 at 06:02 AM. |
Don't use WD40. |
Key properties for any MAF sensor cleaner would be "Leaves no residue" and "safe for plastics"
WD40 would not be acceptable, in that it leaves a residue.
Cheers! Gordon 1997 Ebony #308 113k "The Black Diva"SOLD 1992 Black over Liquid Silver 152k SOLD 1992 Ebony 251k 444 SOLD 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
