Torque specs...
I'm looking for the torque specs for the upper and lower intake manifolds, the throttle body, water x-over, and thermostat housing. Anyone know these or know where I can look them up?
I would look in the How-To Documents. I did and found this page with some of them. I hope it helps.
Thanks a bunch. That page was full of all kinds of useful specs.
It is amazing what you can find in that little section.
Bell housing nuts/bolts; 34-40 ft/lb Drive shaft flange; 17-24 ft/lb Rear diff (2) long and (4) short bolts; 94-116 ft/lb Driveshaft carrier bearing bolts; 35-42 ft/lb 15 minute/$15 mod; 39-48 ft/lb 2 rear diff mount nuts; 45-56 ft/lb 6 trans crossmember bolts; 40-61 ft/lb 3 nuts for trans mount; 20-35 ft/lb Spark plugs; 14-22 ft/lb All cam belt sprockets/pulleys; 14-22 ft/lb The 2 bolts on the timing belt adjuster; 17-20 ft/lb
Got the service manual hosted online at http://serial.cc/ if you want to check it out. You hsould be able to find the specs there easily.
