#121
Re: Camshafts for the EG33.
Who'd you get the cams from? Bill
#122
It looks like the numbers for the ECUTune cams.
'92 SVX LS Pearl White - 6mt |
#123
Also, I will double check the amount of lift with a caliper while i have them off the car when I swap the engine.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 11-07-2012 at 02:28 PM. |
#124
Although I think the duration was a typo - running 264 duration @ 40 thou is 1200 hp drag car spec with advertised duration most likely over 300, not sure on that one. For interest sake, here is the information of my friends turbo cam that we'll be testing soon. These were already proven in 1200 hp setup but as I said he chose to run less lift for lower maintenance reasons. High flow EG33 turbo cam / solid bucket setup from billet cores: Overlap of 109.00 degrees Intake Duration of 318.00 degrees (4 thou) Exhaust Duration is 340.00 degrees (4 thou) Lobe Separation Angle is 110.00 degrees. Inlet Cam centerline of 108.00 degrees ATDC Exhaust cam centerline of 112.00 degrees BTDC Duration at 50 thou = 235 degrees Lift: 9.9 mm (I) and 10.0 mm (E) lift My stage 1 cam / hydraulic bucket setup / basic cam grind: Overlap of 46.00 degrees Intake Duration of 270.00 degrees (4 thou) Exhaust Duration is 276.00 degrees (4 thou) Lobe Separation Angle is 113.50 degrees Inlet cam centerline of 114.00 degrees ATDC Exhaust cam centerline of 113.00 degrees BTDC Duration at 50 thou = 220 degrees Lift: 7.9 mm (I) and 8.7mm (E) lift ****ty Stock cam: Overlap of 13.00 degrees Intake Duration of 247.00 degrees (4 thou) Exhaust Duration is 255.00 degrees (4 thou) Lobe Separation Angle is 113.50 degrees Inlet cam centerline of 114.00 degrees ATDC Exhaust cam centerline of 113.00 degrees BTDC Duration at 50 thou = 187 (I) and 195 (E) Lift: 7.1 mm (I) and 7.9 mm (E) lift Last edited by bazza; 11-07-2012 at 04:23 PM. |
#125
So mine are somewhere in between yours and the stock cams, in terms of duration, but with a little more lift than yours. Think they'll work ok for what I'm trying to do?
#126
Something a lot of people don't realise also is the 1989-1994 RS Legacy and the WRX up to and including the MY96 also had terrible turbo cams. Even with a huge turbo and every supporting mod on the planet you'd only ever make 200 kw atw on a good day low reading dyno - they were attrocious, everything was bad, throttle response, wouldn't rev, low rpm limit, low torque, just nasty. Bin those horrible cams and run some V3/V4 WRX / STI cams and they're better again - ~280 kw atw being the upper limit. Stick some V5/V6 cams in and about the same top end but more midrange better throttle response, better spool etc. After that came AVCS but you get the point - the early cams be it WRX, SVX or RS were all nasty - most likely all ahead of their time back then but time has moved on. I guess over time and millions of dollars of research, Subaru learnt that you can run far bigger cams and still get decent economy, cold start, idle etc and the cams over the last few years are massive compared to the earlier units. So with a cam upgrade - you could seriously weld them up blind folded in your shed and still have an improvement over the stock cams. LOL well not that bad but I think you'd be hard pressed to make a mistake and go backwards, especially if you've got a good shop doing the work. |
#127
Also I forgot to mention - Tony is in the process of sorting out some NA spec extractors for my engine so we can do some NA testing - we just have to get plates and bends etc.
What we plan to do is a few runs with no turbo (removed from car) and the proper long runner style of NA headers as seen in Jack's EG33. Should give us some good info. |
#128
GPXPro: Analogue 1: TPS Analogue 2: Oil Pressure Analogue 3: Boost Analogue 4: Wideband Digital 5: RPM ECUDATASCAN: RPM Inlet air temp Engine coolant temp Boost Timing Injector duty Injector pulse width Accel enrichment Gear Last edited by bazza; 11-07-2012 at 09:53 PM. |
#129
Bazza,
Thanks! "Investment" is definitely the right word! I've got my very rough "experiment on/hack up" heads back, so I'm going to pull a set of intake and exhaust springs off of it. When sticking with the stock springs/valves/hyd bucket is the point at which you have coil bind ( - really a static measurement) coupled with the dynamic behavior of the hyd bucket and the static input of the cam a true measure of the max lift possible? Note that I'm using static here as short hand for "I can easily measure it on the bench with hand tools". How much of a buffer do you figure the lifter is in all of this? Have you taken a lifter apart to see how much "give" it has before it behaves like a solid bucket? Thanks. Bill
#130
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#131
2010 model. Think 5 channel, you'd need to check the tech manuals. |
#132
Half a lap from the other day whilst running the engine in - playing with a 600 hp Mustang.
http://www.youtube.com/watch?v=3eFnBiuQJgA |
#133
Looks like fun! The Mustang definitely had some "poke" in the straights. -Bill
#134
He certainly did. If you look closely in HD mode - you can see everytime on the gas, he is leaving black lines or rubber lol. Think they had an ex V8 supercar engine in it.
#135
Bazza,
Who would have had the faster lap time you or the Mustang?
