Security System Problems
So Here's My Problem. The Security Light On The Security Button Behind The Sterring Wheel Is A Constant Red Light. It Does Not Flash. I Have Tried Two Different Security Modules. The One Behind The Glove Box Door But Both Act The Same Way. I Was Hoping Someone From Our Group Might Be Able To Assist With Some Additional Info Regarding A Rest Procedure. I Have Also Checked The 1 Amp Fuse In Both Modules And They Are Good. Tried Unhooking The Battery And Reconnecting But That Hasn't Made A Difference Either. Does Anyone Have Any Suggestions????
Re: Security System Problems
Need Answer Quickly
A solid light indicates a failed security module. Both of your modules are bad. It is becoming very difficult to find functioning modules as it seems disconnecting and reconnecting them can damage them.
Is there a right and wrong way to remove and put them back maybe?
Unhook the battery first....
