Slipping Transmission Question
Can someone describe to me exactly what the symptoms of a slipping transmission are. I'm a newb with auto trannys.
[B]Tony '95 Polo Green SVX L AWD 62k '05 Ebony Pearl GT LTD Cobb Stage 1, Tein Coilovers, GFB BOV, Pzeros 6k '00 Green Forester S 78k |
Shift lag.
Decreasing accelleration. It would feel like a power loss. If you suspect your tranny is slipping don't rev the engine too high.
The revs go up and the car does not speed up. Stop driving the car, drain and refill the transmission, adjust the trans band, Pray to God. Change the trans filter (in the pan) make sure the trans cooler in the radiator is not clogged.
this is what i was afraid of i believe my trans is slipping in fourth gear. at like 2.5k rpms i'm doing like 75mph. and if i let off the gas it drops down about 300rpm. does that seem like a slipping trans?
Does the tach even read that low?
I'm pretty sure you would stall running if you hit 300 rpm. You could be having a line pressure drop. I had this problem before the rebuild. You might be do for one of the gaskets or O-ring or something. I forget what it is.
no no it drops from 2.5k @75 mph when i'm on throttle down 300 to ~2.2k when i'm off throttle
Oh ok, I had that bass ackwards.
Seems pretty normal to me. The only time your rpms should stay the same is if your TC is locked. I could be wrong. Maybe still could be the same problem, low pressure.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 10-02-2006 at 03:07 PM. |
well today it ran fine. Everything was perfect. I believe yesterday my TC didn't lock up. I guess it didn't get heated up fully or something.
If the TPS is missadjusted the TQ will not lock up!
