Installing Polish bushings .. ?
Got the Rt front control arm out (doing wheel bearing also).. to start installing my Polish poly bushing set.. I've done a fair amount of press work, but I can't figure out how to get the control arm bushings out?? How to set up the press.. to take them out? Am I missing something obvious? I never had this problem before .. ??
HeLp!? Thanks, Jim
Re: Installing Polish bushings .. ?
There is another page somewhere on doing this - anyone else remember?
you can either do it with the press by positioning it over a piece of large diameter pipe with a notch cut into so the control arm can hang while the bushing is under the press or use sockets and some all thread. to do the socket method you need the pull socket to be large enough to grab the bushing but small enough to pass through the hole and the receiver socket to be just large enough that it won't pass through the hole. stick the all thread through both sockets and the bushing, thread nuts with washers behind them until the all thread pulls the smaller socket with the bushing through the hole on the control arm.
was going to do some pics and instructions on this but haven't had time to even check the site for a couple months. hope this helps.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
He and I discussed it over PMs, and he got it figured out. Maybe he took some pics to help the next guy.
The key to using a press is having one of the thingy on the left of this picture:
I believe it is called a bearing separator, sold at Harbor freight.
Ray |
I was wondering what they were called for a while now, thanks.
