Old 10-05-2008, 02:05 AM
dallasvx dallasvx is offline
afterburners on.
Hit a curb, now havingl problems when turning
I accidently ran into curb and am now having problems when turning. My front passenger wheel was the only wheel that hit the curb. The car runs fine when going straight. I notice that when turning either to the left or right that the wheels want to lock up. It is more noticable when turning to the left. I took it to Firestone to have it looked at and they couldn't find anything wrong or broken on the side of the impact. I have read that it might be a problem with the transfer case. If so, would it be the one in the front or the rear? I'm thinking that I might need to take it to the dealer to diagnos the problem. Any idea what a rebuild would cost? My car is an AWD Lsi.
18" Centerline Forged Wheels, Falken Visa Z Rated Tires, Slotted/X-drilled Rotors, Steel-braided Brake Lines, Metal Master Pads. Future mods: Ram Air intake, hi-flow Cat., and drop springs.
Old 10-05-2008, 05:28 AM
Manarius's Avatar
Manarius Manarius is offline
Re: Hit a curb, now havingl problems when turning
How hard did you hit this curb? If you hit it in excess of 2 or 3 mph, I would expect that the axle and wheelbearing are probably thrashed and maybe the A frame/Control arm is a little bent as well. The locking up tells me that perhaps the axle is thrashed and that the guys at Firestone missed something.
-Jason
-Obi Wan Kenobi
Old 10-05-2008, 08:33 AM
afterburners on.
Funny thing is that I wasn't going that fast, less than 15mph. The technician that looked at the car said that nothing seemed to be bent and recommended that I take it to the dealer.
thanks.
Old 10-05-2008, 04:44 PM
Put it on an alignment rack. My bet is you knocked the castor angle back a couple degrees, likely indicating a bent control arm, strut, or knuckle. I'm slightly amazed that your wheel is fine though. 18"+any sort of impact normally leads to the rim being less round than it was before. Get them to throw it on a balancer to check just in case.
