Supercharger on stock internals?
Anyone running a s/c on stock internals? If so how much boost? What can the stock engine handle? I really want to build a block, but no idea how long that is going to take and that intake manifold is going to be staring me down all the time. Lol. I know more needs to be done to manage a s/c just wondering if the stock refreshed engine can handle boost from an M90!
99 OBP LGT Eg33 swapped. 92 pearl LSL for parts. |
Re: Supercharger on stock internals?
Feeling a little spunky today......
A stock motor can handle boost. Look at what SomethingElse has (YT's old car). I think he is running 9psi on a stock motor. An M90 is a bad idea though (heat issues) and one that has been talked about a lot on here. Also, talk to Old Tom about his set up.
Nate has a supercharger intake manifold. If you're serious, talk to him. You will need to get the supercharger separately, and some other stuff, but it's very doable. Only like 9 or so psi has been done safely.
<Missed opportunity?>
It's tuned to the rich side, but on Ultra 93, the Hydra shows no signs of registered knock. I don't know how long it will last (and I anticipate changing the engine someday), but there's nothing kind about the way I treat it. Roots = heat for sure. If you're doing the popular Impreza side-mount w/intercooler gig, you can probably do fine, but I'm a little leery about the idea of an inverted, intercooler free setup. With a twin-screw on 9psi uncooled, you're looking at 180*F going in as it is.
I would be willing to sell my supercharging set up and all supporting pieces (minus the EMS)
I will have to check the topic on the M90. I wont have the clearence issues like the Svx has though with my hood.
