Trans cooler LINE question
I've searched and not found a definite answer-- for the stock trans cooler that's internal to the radiator, which line comes from the tranny and which is the return line? One line attaches to the right side of the bottom of the radiator and one to the left. Mine's a '94 with no external filter, so no help there!
Re: Trans cooler LINE question
The line FROM the transmission connects to the radiator on the passenger side. The return line FROM the radiator TO the transmission connects to the radiator on the driver's side. Just disregard the external ATF filter as external cooler .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 08-08-2010 at 06:39 AM. |
The diagram that John posted can be misleading.
The important part is that the fluid out of the transmission comes from the line that exits the transmission just behind the bell housing. The line that returns fluid to the transmission goes back farther along the transmission on the drivers side near the tail housing. The only way to be sure of your cars CURRENT routing is to start at the transmission, and follow the lines.
Thank you SVXfiles-- That's more helpful since I think my lines into the cooler may have been switched when the previous owner had the tranny rebuilt. I was about to ask the question again in reference to where the lines connect to the tranny, but you beat me to it! (and John, thanks for the diagram, too)
Any time a person installs a one way only transmission filter, they have to follow it from the transmission lines because its very easy to switch them at the rubber connections. More than one transmission has been starved of oil because of this easy mistake.
Ok, so here's my follow-up question: My research on the site seems to be that it's best to install an aftermarket cooler in between the tranny and the stock cooler so that fluid goes from the tranny, into the aftermarket cooler, then into the stock cooler, and back to the tranny. Is that correct?
And my opinion,(and that of LAN) is that if you do anything at all regarding the transmission cooler is to REMOVE THE FACTORY TRANS COOLER FROM THE EQUATION! If you try to blow air through a stock in-rad trans cooler, you will see just how restricting it is. Bypass the stock trans cooler and run an aftermarket cooler mounted anywhere you like.
Not doing so causes other problems. See: http://www.subaru-svx.net/forum/atta...3&d=1270929226 |
How does that help?
For proper transmission opperation you want at least 150°f and less that
200°f. If you can moniter the temps then you can fit a cooler that is correct for your climate/location. An SVX in hill country would need a bigger cooler than an SVX where there are no hills, for example. An SVX in a big city with bumper to bumper traffic would need a bigger cooler than an SVX in "Mayberrry."
If you use the proper sized aftermarket cooler, sandwiched between the factory radiator, and the factory AC condenser it works fine, without placing a restriction on the transmission pressures,LIKE THE FACTORY COOLER DOES! We live just outside Cumberland Maryland and see below 0°f during our winters. We drive SVXi every day. With the proper sized cooler it is not a problem, but a way to help our transmissions.
-Bill
