#1306
Re: SVX Engine cooling "Again & Again"
A PDF (3d) of what the final unit looks like.
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#1307
Bazza asked for more info on how they are fitted.
Cut 50mm off the front of the top pipe then the new housing slips over the pipe and is welded on. Need to also cut off a bit of the power steering support bracket. Tony
#1308
Looks good, I would much rather pay for that, rather than a universal one, even if yours is a bit more expensive. Much cleaner.
cheers -Evan |
#1309
Sign me up for one! My only suggestion/request is for those of us who don't want to start pulling the top front of the engine bay apart and then have to get a qualified aluminum welder to work his/her magic. Can you design in a short stub on the backside (with a circumferential bump for sealing) that would allow for a short section of silicone rad hose line to be used to pipe in the thermostat housing in lieu of welding? Thanks!! Bill
#1310
Since I was out to see Shotgunslade today for a minor tuning session, I figured I would snap a pic
Tom Last edited by TomsSVX; 09-23-2012 at 07:31 PM. |
#1311
B
#1312
Im sorry i forgot it was have tom do all the work day
Tom |
#1313
Finally finished digging through pages of the old build thread... link is dead now but it was from a company called wilson manifolds
Tom |
#1314
#1315
Only because Bill was having absolutely no luck finding it after searching for ~ an hour
Bill
#1316
How much benefit would there be from just moving the t-stat up top?
#1317
Tom |
#1318
Did you guys datalog the temps before and after - at both the head and pump suction?
#1319
All my road cars have larger suction pipes on the water pump. If you plan to rev the car above 5k for any resonable period and don't change the suction pipe to the water pump you will cook your engine.
That's my experiance and I would have spent more hours running tests on the cooling system on these engines then any person on the planet, I would even go so far as to say more then Subaru other wise they would have figured it out as well. Maybe they have as the Tribecca has a large suction pipe they just haven't figured that the thermostate won't work on the pump. Thats my two bobs worth, now to go back to the 10k project. Tony
#1320
