#1231
Re: SVX Engine cooling "Again & Again"
Whatever can help to reduce operating temperature may help reduce head gasket issues. If there is a "kit" of hoses, an inline tstat, a specialized pump cover and maybe a radiator outlet expander, it could help us daily drivers. I was thinking these items could be added to a stock radiator or an upgraded radiator. Is there a parts list like this and someone that supplies each of the parts? Any high stress reliability test includes two items; damp heat and thermal cycling. We have both in an engine cooling system. Now, if you have a cooling system that is marginal and restrict airflow to the radiator by, say, throwing a transmission cooler in front of it, you have to be making the problem worse. That makes an improved cooling system even more imperative, even for the daily driver.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#1232
I am convinced that if there are no other factor (leaking radiator, blown hose etc) at play the poor coolant flow is the problem to blown head gaskets.
Forget the standard radiator it won't cool the engine when you want more power, The other question asked about top pipe etc, if you want to get the best cooling due to increased power you should consider changing to a cross flow radiator, Thats my 2 bobs worth. Have a great day. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#1233
I also looked into alternative pumps and discovered that the European SVXs have an extra nipple on the pump for an oil cooler. It wasn't clear to me if the nipple was on the positive or negative side of the pump. It also wasn't clear where the other line from the oil cooler went. It looks like it goes into the block. If that is correct, is it possible that this secondary path through the oil cooler helps to reduce or even out the engine temperatures by balancing flow or heat load load between the two sides of the engine? If so, I might consider replacing the US pump with a euro pump and oil cooler when the time comes for a pump replacement. I have also been looking into better fans but have had no luck there. The radiator could clearly be upgraded to the PWR but that is an expensive fix for something that may not even be broken! And is there something that can be done with coolant and additive choices to even out or reduce temperatures? Redline's water wetter has gotten good reviews. When mixed with 50/50 coolant it brings the engine temperature down 8F. That isn't much but it may help a cooling system on the "edge". It also supposedly helps even out the temperature and that may be more important than the temperature reduction. Also, for those that live in warmer climates, you get about a 1F reduction in operating temperature for ever 1% reduction in anti-freeze. Going to a 45/55 mix will reduce temperatures by an additional 4-5F, for example. On the anti-freeze choice, wow, that is a confusing mess. Here is what I have been able to gather so far: Aftermarket Green: Low silicate, zero phosphate inorganic ethylene glycol Subaru Green: Zero silicate, zero amine, phosphated HOAT ethylene glycol Yellow: Low silicate, zero phosphate HOAT ethylene glycol with nitrites to reduce cavitation Orange: Zero silicate, zero phosphate OAT ethylene glycol dex-cool (bad stuff known to cause head gasket issues in GM cars) Red: Zero silicate, zero phosphate OAT ethylene glycol with special anti-corrosion, anti-cavitation and anti-foaming additives Pink: Zero silicate, zero amine, phosphated HOAT ethylene glycol Blue: Not a lot of information on this new stuff but it may be propylene glycol and is known to not mix well with water wetter additives. Propylene glycol is supposed to be less toxic and a better coolant because it has a higher heat capacity, lower viscosity and lower weight density. It also has a slightly lower thermal conductivity relative to ethylene glycol but that is supposedly out-weighed by the benefits. It seems like the pink stuff (Zerex Asian, for example) is the only direct alternative to the Subaru green. The yellow stuff (Zerex G-05) appears to be an improved version of the aftermarket green stuff. Either greens or the yellow or the pink appear to be compatible with water wetters. A slightly reduced concentration of any of these plus water wetter could reduce engine temperatures by 12F or more and may help even out temperatures and avoid cavitation at high RPMs.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything Last edited by Huskymaniac; 10-20-2010 at 06:44 AM. |
#1234
I have the crossflow rad with the 2" outlet for about six years now. Picks in old locker.
#1235
If you start at cheapest and simplest first.
1 Move thermostate to top as Svxfiles did, this is the most important. 2 Change the inlet pipe to the pump, "Thermostate cover" 3 Bigger radiator. 4 Outlet pipe on radiator 50mm and noved to the centre of the bottom top (only if not a cross flow radiator). 5 Crossflow radiator. 6 Top engine pipe (this importance is determined by revs). . As regards coolant personally I don't think it will provide enough help to gain anything, the problem is one of flow but maybe I don't understand were the gain is. Tony
#1236
^ Thank you, i was hoping somebody would just make a simple check list.
Also, where are you guys getting your t-stat relocation kits? what diameter? what temp t-stat are you using in it?
94 Acura Integra GSR 97 Legacy Brighton - EG33 Swap still in progress 03 Silverado 2500 - Duramax |
#1237
About #4. What if the inlet is in the middle of the top? It seems to me that would allow thw quickest path to the outlet with the least benefit of the radiator. Thats whu on my next radiator the bottom/outlet will be close to the stock location. Please feel free to correct me if I am not thinking correctly.
#1238
My car has been running excellent since this work. No overheating issues whatsoever and in fact, the car may be running too cool at the moment with the coler temps approaching. I can flog down a long road in these temps and be as low as 158F. that's with a 170 thermo in the housing. Again temps are dropping here and the airflow I have a the front of an impreza is qute different than that of an svx. On the list above, #s 1-4 all go hand in hand. you really should be swapping out for a large aluminum core, and doing the subsequent housing and cover modifications all at once. To simplify things, one should have the radiator outlet position directly in front of the pump. This, coupled with appropriate 50mm connections, amkes the plumbing simple....just a simple 90 degree 2" id hose is all that's required. nothing fancy. Fan fitment will require work for stock fans, but at that rate one should be considering aftermarket slim units regardless. |
#1239
The top of the radiator is under pressure and as a result the flow is less effected by pipe postion. The bottom pipe is under suction and has major flow problems related to pipe postion.
Give you an idea I had PWR built for me, a new design radiator about 6 months back. It had the top and bottom pipes made bigger 45mm but still at the standard position. When I put it on the test bench I near cried because at high revs you could see the air coming from the pipe at the radiator outlet. You can imagine how upset I was. I was so frustrated that I installed a pump only no motor and sent the liquid around in a loop. I could get the pump to work air free at 9,000 rpm (had to change the thermostate cover to 45mm. The water was so clear that it was difficult to see that it was flowing. Then I went back to the engine, looped flow around and got Zero air. As a result I changed the suction on the radiator to the centre and at 6,000 got Zero air above that had a bit. Hope that helps, by the way I have to do a right up on MRT here in Australia about this when its done I will post a link for all to see. Hope you all have a great day. Tony
#1240
OK, Tony, the next rad I have remade will have the outlet in the middle bottom.
#1241
#1242
Yes, I know how frustrating those pointless debates were, for you and for those of us trying to follow. Nothing positive about it, nearly unbearable. Thanks for hanging in there, much appreciated. Your work on this cooling fault was fantastic, one of the best threads we've had here. You were the right man to sort it out mate Ron
Special Thanks to Our Friends and Sponsors: * http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/ http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston "QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works, '92 Subaru SVX LS-L Claret ORIGINAL OWNER '92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~ '92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143 '92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117 |
#1243
and it'll go in my SVX
#1244
Hi all there is a story on the cooling on the MRT web site. I have tried to aklowledge everyones contribution. I wrote the artical trying to be a little light hearted with it as well. Thanks everyone for helping get this problem sorted.
http://mrtperformance.com.au/resourc...boiling-theirs Hope you all in joy. Have a great day. Tony
#1245
Great article Tony.
I am also interested in one cover, what do you mean straight lip?
