#1141
Re: SVX Engine cooling "Again & Again"
Hi Joe its great to get your input. I think it would be good to get this sorted out so its clear for everyone to understand.
At 7,500rpm the coolant can move 153 kw of heat at 3,000rpm it will only move 61 kw of heat. If you slow the pump you won't get rid of enough heat. I am a bit short on time to debate this to far so I will come back to it tonight. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#1142
At long, long last a smidgeon of common sense has been recorded within a thread which has become ridiculous. However you suggest further testing with regard to the engine block. Most of the thread has been taken up with this angle of approach, and several alterations have been carried out to no avail. The cost and complications involved with testing and modifications to date, far exceed that involved with my simple suggestion, which has stupidly been continually resisted and ignored.
#1143
Tony
#1144
No specific advice has been posted to cover a universal fix. There are obviously several still seeking a solution. Rather than take a chill pill in accordance with your very direct instruction, as a worthwhile alternative, I request that you please kindly assist those still in need. Meantime Spitting out the dummy you continue sucking, could prove a worthwhile move.
#1145
As the pump speed increases, the flow increases, to increase the pressure differences across the system, causing the cap to blow pressure, and the pump's inlet pressure to drop to cause boiling at the impeller. I think it would be worth a try to fit a pressure operated valve to join the pumps outlet, back around to the inlet. This way all is standard till the pumps speed increases to the point, that the pressures would cause the problem. The increased pressure across the pump opens the valve to connect the inlet to the outlet, reducing the pressure difference to prevent the troubles that it causes. The port on the pump's outlet could be used to connect it back through the pressure valve to the heater feeds, on the pump cover. It would take a bit more research to find the right pressure for the by-pass valve to open, and the amount of water that it recirculated. Nothing that your research lab can't do, a?. Harvey.
#1146
Hi Harvey good to get your input,
Steve and I spoke about the problem and he is doing a simlar thing to what you suggested (Great mind think alike). In the short term he has connected the back of the head hoses to the pump side fitting. We feel sure that will reduce the problem but I don't expect it will solve it completly. Untill the weekend I didn't really appricate the issue of getting flow throught the radiator. I was straching my head thinking how the hell am I going to get coolant to SUCK through the radiator, also if you remember every time I tested the radiator in the start at higher revs coolant came out the overflow. Now we have the answers. Was looking at a Ford radiator with side tanks and even it has the cap on the suction side. With out trying to sound to insulting to Subaru you got to wonder what the hell they were thinking when they did the cooling on these cars. The problem seems to be they assumed it would work. Tony
#1147
So I started looking for an alternative and I bought a JDM Legacy rad (sorry dunno which year, the guy selling the part wrote on it "Legacy"). That rad had side tanks, was wider and a few mm thicker than the SVX's. I am sorry to say that cooling went worse than it was before. I couldn't speed uphills without the car overheating. This is from personal experience, same rad, different position tanks, OEM design wins.
#1148
Yes, a pressure difference is the problem, i.e. exactly as I have continuously been pointing out throughout this thread. However the actual problem involves the difference in pressure, delivered by the pump at abnormal RPM, when compared with the optimum designed pressure applicable in respect of the radiator and overall flow path. As a result of the optimum flow rate of the radiator being exceeded, the top tank pressure becomes abnormal and the pressure cap releases coolant as a result of the excessive pressure, i.e. it does its job well. By way of an answer to his question, Tony should accept what I previously advised and note that as a result of the resistance offered by the radiator, once the optimum flow rate is exceeded, the pump will become starved and a vacuum will develop at the pump inlet. Again the mugwump bird will be in full flight. N.B. Fitting “a pressure operated valve to join the pumps outlet, back around to the inlet”, i.e. a pressure controlled bypass, is an excellent idea. However this does involve some mechanical complications, as well as the necessity of obtaining a suitable valve. This should preferably be adjustable, and components from a reducing valve could provide the means of making up something suitable. This should fall well within Tony’s area of skills and could be an interesting project. P.S. It could be possible to make something up, using the guts of a radiator cap. This would provide a suitably calibrated relief valve and several variations would be available for experimentation.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! Last edited by Trevor; 08-17-2010 at 02:43 AM. Reason: P.S.Addition |
#1149
Actually the Subaru engineers should be complimented. They were exactly accurate and were able to establish and work within very close tolerances when establishing optimum levels. The SVX was not designed as a desert racer.
#1150
SH_T "hell must be freezing over" Trevor agrees with Harvey I need to get that posting framed. Great to think you guys CAN agree.
In all seriousness I agree that we can put in a bypass valve and get round the problem in the short term. Long term I thick we need to find a more perment soluation. The bit ticket concern I have is the coolant not going through the radiator and therefor reduce effiency. We need to pressure feed the radiator to get the flow up. Danny thats good to hear, Do you have any photos of the top and bottom pipe also were the cap is in relation to the outlet. Tony
#1151
Tony, you are in Luck (you could have asked for a million dollars ). I was checking my files and I do have some pictures of that Legacy rad fitted before I switched to PWR... It was a tight fit especially with the legacy overflow tank. Also in the pictures you can see "Legacy" "97" (pointed to it in red, 97 written in arabic). The upper and lower metal frames are just frames to hold the rad and fans, the tanks are on the right and left.
#1152
Side tanks, what six years ago? Why is Trevor being,,, like he is?
#1153
Therefore you should be guided accordingly and take very special and serious notice of what we have to say. Quote:
If the flow rate is increase a larger radiator will be required, but then you will be up against the problem of a flow rate which is too high, passing through an engine designed for much less. The problem involves two very distinct factors and both must be taken into account. Both Harvey and I are not making suggestions on the basis of a temporary or short term fix. We are are talking about probable permanent and final solutions. Please note my P.S. now added to my previous post, regarding a way to make a suitable valve to suite what Harvey has in mind.
#1154
You posted:- “Was looking at a Ford radiator with side tanks and even it has the cap on the suction side. With out trying to sound to insulting to Subaru you got to wonder what the hell they were thinking when they did the cooling on these cars. The problem seems to be they assumed it would work.” You stated, “according to Subaru”, and then by association clearly referred to Subaru engineers. I was again trying to press home the logical and valid point that the SVX radiator was designed to operate at an optimum level. It was/is not badly designed.
#1155
I am amazed the ford radiator looks exactly like I would like to use. The outlet size is large and also up a bit from the bottom to get better flow. Would love to test one of them in the bench.
Danny I think the problem with the one you had was the tank were very small and my have killed the pump, the PWR are better then the standard SVX radiators. There are a couple of issues with having a bypass valve back to the pump, As I understand it the cap lets go at 14psi. Currently on a standard PWR the top tank pressure at 6k rpm is 7psi What ever we set the bypass at it has to come off the cap release pressure. We can't simply put a higher pressure cap on because when the revs drop the blow off Temp will change. The second and my biggest concern is getting rid of heat load and to do that I need every litre of coolant I can get. If you remember all attempts with electric pumps have not had enough coolent flow to cool the engine so I not sure how the bypass will get around this problem. What I am aiming for is to cool a race engine that develops higher power then standard and to that end I need everything in the system to work to maxium. Have a great day. Tony
