#826
This.
(profanity) Enjoy.
#827
@NikFu - what kind of tires do you have on that thing? It is a fairly steep driveway though I'll admit, I was really expecting you to make it up there!
1994 subaru svx le 112k |
#828
Shoulda turned the rap off - then you would've made it
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
#829
No no, he was tackling it like a Thug and had the appropriate music on (I kid) perhaps the track should have been something far more aggressive however
#830
put new rims and tires on, will have pictures later.
#831
Well, someone is a music prude. I actually did try the hill again today with different music on and I made it up, so maybe you are on to something.
#832
made my non exsistant exhaust beautiful again
and dis assmebled wheel bearing, sent hub to the shop. broke my abs sensor =/ fixed power steering leak.... AGAIN |
#833
Put my new Maniac alternator in! I couldn't unbolt the tensioner... I was starting to round the bolt off. But, using my resourceful, pre-engineering skills, I was able to get it off anyways! I just unbolted the alternator, pushed it down as far as I could, then used the slightly larger amount of slack to push the belt off one tooth at a time, by turning the alternator pulley. It worked! Got the new one in by the same principal, and then used the leverage from that final screw to put the tension back to normal.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
#834
#835
as mentioned here are a couple of teaser pics of the new rims Will get better pics after washing and finding a good background.
these were taken with my cell phone. |
#836
I take it to a garage, and let them handle it.
#837
Had the pleasure of driving it in first and third gear only :/
Frantically trying to source a 4.44 tranny.
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#838
or spend 20 bucks on the stretch belt tools. they are meant for installing the stretchable belts on new subarus. looks like two little shoe horn things, one takes the belt off and one installs it. they work great when you just can't get enough slack.
I have these but the cheaper one is the same idea. http://www.google.com/products/catal...ed=0CCYQ8wIwAA |
#839
I like them. What wheels are those? Rotas? |
#840
Didn't know they had these!
