Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #736
Old 11-28-2007, 01:44 AM
Dessertrunner's Avatar
Do you mean a Subaru Select monitor?
Old 11-28-2007, 01:58 AM
Yes, that's the device.
Old 11-28-2007, 11:54 PM
Help me out here I can't remember if the unit give's a Knock sensor reading or not. Reason I ask is this if it does I can borrow a unit here in Oz and see what my engine is reading.
Tony
Old 11-29-2007, 02:53 AM
Tony
The Subaru Select Moniter reads the timing advance, and gives a second reading for retard.
It (the knock sensors) can pull timing up to 32 degrees.
Old 11-29-2007, 04:58 AM
It can pull timing up to 32 degrees.
Thnx Tommy boy
Old 11-30-2007, 12:59 AM
thanks for that I borrow one occusionly and didn't under stand some of the info you are getting from the unit. Tom when is the big day for the test?
Old 11-30-2007, 11:01 AM
sometime this weekend if I have time.
Old 12-01-2007, 09:43 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
YT,
Wide band should be on your doorstep by Tuesday. Sorry for the delay, I got totally tied up with work...
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 12-04-2007, 05:56 PM
Hey, no biggy, cannot use it until after this weekend anyway.. Plus... it didn't get here yet.. maybe tomorrow??
Old 10-22-2009, 02:12 PM
longassname's Avatar
Just some dude.
Re: ECUtune Stage III development
I'm about to build a new blower system for my car. The lack of hood clearance for the blower pulley in line with the factory pullies was a major obstacle and draw back of the first systems. To avoid this I am going to make a custom alternator with a timing pulley mounted on it's back side. This will let me mount the blower with a "non drive kit (pulley mounts on the front of the blower with no extension drive) in the traditional fashion blowing downwards to a tubing manifold.
I will be using twin intakes with a pair of SVX maf meters and sr20det 370cc injectors with the new aggressive style ECUtune software.
I've ordered a couple of 160 amp alternator rotors from maniac electric to extend in order to mount the timing pulley (two because I'm going to make one for Jon's car too). I'll send the modified rotors and a couple core alternators with machined cases back to maniac electric so they can assemble remanufactured 160 amp alternators i can mount timing pullies on. I figure as long as I'm putting the time into making custom alternators they might as well be a big upgrade to the charging system as well.
Old 10-29-2009, 12:07 PM
sicksubie's Avatar
370cc injectors will flow enough?
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 10-29-2009, 01:42 PM
mikecg's Avatar
mikecg mikecg is offline
Remined me again why you choose the S/C as apposed to a turbo system.
Old 10-30-2009, 11:49 AM
Phast SVX's Avatar
BOOOOOOOOOOOOOOOOOST
Cool beans.
~Phil
Old 10-30-2009, 11:50 AM
Phast SVX's Avatar
working great for me at 15 psi.
~Phil
Old 10-31-2009, 07:02 AM
Just some dude.
Because I like a challenge. Not really, right now, mainly because I still have a couple of them.
