#706
Re: SVX Engine cooling "Again & Again"
FYI,
I sent an email to PWR/US this morning asking about either shipping my radiator to them to have the existing outlet replaced with a 45mm piece or having them ship me a 45mm outlet that I can have TIG welded on. -Bill
#707
Bill:
Have you been having overheating problems. If so, can you describe how they occur, when they occur, whether they are specific to any specific usages factors when you're on the track, and how they manifest themselves. Dan
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#708
Only when I autoX (45-75 seconds of high rpm driving). Manifests at end of run when I'm back in the paddock area and the coolant recovery line is spewing all over the driver's side wheel well. -Bill
#709
So, that is worse than mine, because mine usually didn't start vomiting Prestone until it had been running around the track 15 minutes or so.
#710
I should have added that it usually isn't the first run of the event when it happens. More like the third I'm guessing you get more airflow and the on-off the gas is more gradual. -Bill
#711
Just a thought about modding the outlets on the PWR rad. My upper hose is already basically sitting on the fan housing and the top of the inlet is flush with the top of the rad. To run a larger inlet you would need to cut into the fan housing. How much room is there to the fan blades below that?
#712
My impression to date is that it's the radiator outlet and thermostat cover that need to be "upgraded". I don't believe it's essential to change the radiator inlet. Tony should pipe in here to set things straight. -Bill
#713
How long is it between your runs, and do you turn it off between runs? I would often slowly drive around the infield roads, maybe even off the track property, 3rd or 4th gear, low rpm, 25-30 mph, until the temperature gauge stopping spiking, then bring it back to the paddock and shut it down.
#714
Guys the top inlet pipe on the radiator is okay as it stands so don't bother changing it. Its the bottom that is the issue so change the pump cover and the outlet pipe on the radiator to centre of radiator and both 45mm.
As regards other types of coolent I agree they they may improve a bad problem but they won't make it go away. If the visciety of the liquid is thinker then existing coolent the problem will be worse. A vacum is a vacum and different type of liquids won't change that other then a change in the liquid thickness. The oil type coolent that was in my race car when I brought it didn't stop it boiling for the last owner. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#715
Sound advice and good progress. I note that you have now correctly dismissed the theory previously championed by Harvey, but argued against by me, concerning the inlet and cross pipe. It is unfortunate that in this regard, much time and effort was uselessly expended. Removal of the thermostat, increasing the size of the pump cover and or the inlet pipe, appear to be the deciding factors. There is no real evidence that central location of the radiator outlet pipe is of value. Scientific analysis, similar to that applying to the cross pipe, would suggest otherwise. This could be an inconvenient modification on several counts. As I understand it, tests in relation to an actual SVX installation have yet to be completed. Surely in case of further developments, it would be wise for those involved to delay committing resources meantime.
#716
It a issue of "Bang for our buck" I may race car I will change the top pipe as it will help flow but if it doesn't happen its not that big an issue.
In terms of the changes in a SVX the only factor I see as possiable limiting is that the radiator fin count could be two high if the cars are racing at slow speed. We have to get some return coolent temp numbers after mods to get our head around that. Steve's radiator is multi pass so its a lot more powerfull for a given size. I hope to install my PWR soon and it has 14fpi so measure airflow and return temp etc. Tony
#717
SCCA autoX doesn't give you that option. End of run and drive back to paddock and shut down. -Bill
#718
Definitely looking forward to hearing how your SVX runs! Just so I'm straight on its configuration, is the following correct: 1. PWR radiator (specific to the SVX, believe it's PWR part # is 5229) with 45mm outlet (modified) and 33 mm inlet (stock), 2. Stock radiator cap, 3. Stock water pump 4. Modified thermostat cover - 45mm inlet (vs stock 33mm), 5. Modified cross over pipe (top of stock pipe removed and new aluminum added to increase cross section), 6. Stock rad fans, 7. Stock thermostat Thanks again for all your efforts on this!! -Bill
#719
Tony
#720
Thanks for the confirmation! Looking forward to the road testing data!! -Bill (fingers crossed that Tony runs cool!!)
