#646
Nice. If they're anything like what I've got on my car, you'll love them. Try and get some pictures of what they look line and the part numbers for all the stuff they use, especially the struts.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#647
Not today, but last night I finished the wiring for relocating the battery to the trunk in my blue car. Pics: https://picasaweb.google.com/1129523...ocationProject
All that's left is to get a better tie-down. The stock tie-down is too tall for the battery I've got. That one that they sell at advance all the time will probably do the job. I can write up a how-to if anyone's interested. o_o
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() Last edited by icingdeath88; 11-18-2011 at 12:24 PM. |
#648
No air (A/C) in Florida? I don't know if I like the look of the 4 wires tied together with a bolt. Is that the + wire?
#649
Yea, no A/C for the time being. On hot days I just use the other car. It really doesn't bother me though. I have all the parts to add A/C back to it, but I'm undecided whether I will or not. Either way, not till after winter
![]() All the electrical stuff actually seems quite a bit stronger since I did this. Car runs just a tad smoother too.
#650
Getting my rear wheel bearing replaced. That's #2 and I think it was replaced already by the previous owner.
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#651
^ If this bearing doesn't last you should get another hub.
#652
The grease on it looked pretty cruddy. It could have overheated due to the bad bearing but I am wondering if they used some crappy aftermarket seals which let dirt and water in.
#653
Scheduled it to get the cv axle replaced. All I hear is WHOM WHOM WHOM at 60mph and ker-thunk as I turn the wheel at low speeds.
This spring I should have enough to completely restore the car, but sorry ladies, daddy is getting a new car.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
#654
motor swap....thanks to Nate. long live 94 teal !!! 4.44 is next on the list.
#655
Today, I ordered 2 new front sway bar end links, purchased second hand drive shafts (100,000kms) and hood struts from a local who bought a half cut for a VW SVX Van.
![]() ![]() I also installed new Porsche Purolater oil filter and replaced oil (all by myself) ![]() This week comes the install of the end links and front drive shafts and D bushings. Hope to finally cure front end noise. Still have to get A/C serviced (it is REALLY hot in Australia now) and find some rear struts or inserts before next roadworthy or it will FAIL! ![]() Looking forward to a silent ride. Oh, Happy Birthday to me.... ![]()
1992 SVX Mica Red/Black (Ruby Pearl) (ADM)- 290,000 kms. With Koni adjustable front shocks, THRICE o/hauled 4EAT with transmission cooler and now the 'QUICK CHANGE' unit, custom PWR aluminium radiator, replacement water pump, fuel pump, crank pulley, Pioneer 6 x 9 rear and 6 inch front speakers, Sony Head unit, rattles from the front end and steering, front DBA slotted rotors. Blown heater core, ruined CV joints, new car park damage. FOR SALE... www.thebeatleboys.com |
#656
New Conti DWS tires. Have driven in dry and rainy conditions. 100% pleased!
#657
1994 subaru svx le 112k |
#658
Replaced yet another headlight on the Tribeca. Had to remove the battery to do it. What a PITA!
Pulled the inside panel of the door off and used Quicksteel to repair (I hope) the broken weld inside the door. Thanks to whoever it was that suggested it.
#659
Had the front left CV replaced. Was only in the shop a few hours. $270 later the clicking and shuddering that developed over the weekend is gone, but there is still a low whirring noise...
#660
Not so much what I did to my SVX, more like new accessories I bought for it. Craigslist is great, I found my blue '97 there, chromed SVX wheels and today I picked up an SVX OEM bra and clear headlight protectors along with an original '92 SVX brochure. Even though I will only use the protectors and bra for highway trips and not around town, I am ecstatic
Dave 1997 Laguna Pearl LSi 39 000 mi 62 000 km 1992 Claret LS-L Sold 105 000 mi 169 000 km 1988 XT6 Written Off 111 000 mi 180 000 km |
