Old 03-02-2012, 08:40 AM
STeeL25T STeeL25T is offline
Soon to own a fuctional SVX
Send a message via AIM to STeeL25T
Re: Manual swap, not starting
Does anyone have an alternate part number for that relay? I brought the one listed to NAPA and they told me the closest one in any store is in Indianapolis and it would cost more in shipping to get it here than it costs... So maybe a number for Auto Zone or something?
Old 03-02-2012, 09:51 AM
Any relay of the same spec should work.
http://www.amazon.com/TYCO-BR-1000-3.../dp/B0075TCNX6
Old 03-02-2012, 03:21 PM
If the relay that you used to replace the Security one is a 5 pin relay, you can use that type, just use the normally open contacts.
The main thing is that the coil in the relay has to be 90 ohms or less. If it has a much higher resistance, the Cruise Control signal may have the starter work, when put into P or N.
Old 03-03-2012, 04:06 PM
I pulled out the whole center console, which appears to have been a huge waste of time because literally the only thing under is a black box with a plug going into it I could easily reach and already have just by removing the little cover under the parking brake. That box says right on it "Shift Lock Unit" so I can only hope that is what Tom is taking about... But I've already tried unplugging this once and it made no difference. Tried again for good measure and no change.
Old 03-03-2012, 04:09 PM
Leave it unplugged, and take the module out, it no longer serves a purpose. Find the wires mentioned earlier near the shifter and connect the two wires.
Old 03-04-2012, 02:58 PM
Good news is running a jumper wire to tab from the battery makes the starter work.
Bad news is adding the jumper wire to the white plug still did nothing to release the key. If I had some issue with the switch on my brake pedal, would that cause this?
Old 03-04-2012, 03:09 PM
Ok, then do the relay thing, and you should be in good shape here on out.
I don't think so. Normally, once the car's in park, you can take the key out regardless of whether you're pressing the brake pedal or not. Are you entirely sure you jumped the right wires?
I'm trying to think back to whether I did anything else with wires when I did my swap. There were only these 3 things:
- Wiring for the reverse lights
- Wiring the NSS to a switch on the clutch pedal
- Jumping those two wires next to the shifter
So I'm not sure about the key issue. I'll think about it more, and test whether that 3rd thing is for sure related to the key or not.
Old 03-04-2012, 03:29 PM
Well, I just went out and checked, and the key came out just fine without those two wired jumpered.
The shift lock module you left unplugged right?
Old 03-04-2012, 04:53 PM
Still unplugged.
I wonder if there is problem with they key itself then.... It was looking a little bent if I recall.
Old 03-04-2012, 05:33 PM
If it is in OFF you should be able to push the little lever under the steering columb ( release tab) and pull it out
Old 03-08-2012, 08:23 AM
Would that be the one at the very bottom and back of the steering column that isn't labeled? Didn't work either if so.
Old 03-09-2012, 07:00 AM
Copied and pasted from another source"
I just ran out to look at mine.
It is down at the base, right next to the lever to adjust the height. Not the height release on the side, but the height adjustment on the bottom center.
The metal tab is in a white plastic block, you can sort of see the spring holding it, you need to slide the tab towards the height adjustment button.
Once pressed, you still need to push the key in to turn it back.
Old 03-13-2012, 05:21 PM
Just as an update, the Bosch relay fixed my starter issue right up and the lever under the steering wheel got my key out and it hasn't been locked again since. Thank you all! Just one more problem to tackle now...
Old 03-13-2012, 05:55 PM
Cool. I wonder why the key got locked in the first place. Maybe the shift lock unit locked it in there, and then it got unplugged and couldn't tell it to unlock anymore?
Old 10-11-2012, 09:48 AM
BRZCory BRZCory is offline
...it a 25th time and magically the starter starts going and the motor tries to crank and it either doesn't or it will for about 3 seconds before the check engine light comes on, the gas pedal becomes useless, and it winds down til it dies. The process repeated about 5 more times before I gave up.
Did you ever find a fix for this? I'm swapping my impreza with an SVX motor, and it *tries* to fire up, then dies. So I'm looking for straws to grasp at now.
Thanks!
