Old 10-23-2010, 04:50 PM
Re: Wants to overheat
Originally Posted by Michael Blue View Post
Gonna have him look at the wheel bearing while he's got it...
Anyone have a quick link to the proper "how to" on these?
I know there's a trick to it...
Really only 2 things you have to make 100% sure that a shop does:
Change the grease on the wheel bearings from the shipping grease that comes on them to a real wheel bearing grease. Mobile 1 makes a great synthetic grease. I'd pick some up and take it with you so that they have no excuse for not changing it.
Don't overtorque the axle nut. If they're in a hurry, they'll just put it on real quick without making sure not to overdo it. Watch them to make sure they don't do this.
Also, anyone know where I can source a windshield inexpensively?
Best way is to get one off of a parts car in your area. People are reluctant to ship them, so they're pretty difficult to get used. There aren't that many new ones left at all, and they're super expensive.
Old 10-24-2010, 09:56 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
(So much for "being right all the time )
Hmmm who said that?
Old 10-28-2010, 11:44 AM
Michael Blue's Avatar
Michael Blue Michael Blue is offline
Sold. :'-(
OK, update...
Water pump/timing belt are in...
No more overheating issues right now.
Going to go ahead and do the rear wheel bearing, too.
*Yeay!*
'92 Pearl White LS-L Touring SOLD
4.44 Swap, trans cooler, trans filter, trans temp gauge
Color-matched rear body and spoiler, X-drilled and slotted rotors, Axis pads, s/s lines
Raxles front axles
Old 10-28-2010, 11:49 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
head gasket: $50.
labor: $1200.
thought i had this problem,
i considered getting a used engine.
it was cheaper.
turned out, the only thing wrong was a bad timing belt. ($150)
this broke the timing belt cover ($85)
the warped belt then broke my 4 idler pulleys ($500)
and ruined my water pump ($200)
and blew up my radiator ($200)
stupid laws of the universe for things going wrong.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 10-28-2010, 11:53 AM
Sold. :'-(
$150 timing belt?
O'Reilly has them for like $88.
I got the (lifetime reman) pump there, and will probably get the wheel bearing there, too.
~M
Raxles front axles
Old 10-28-2010, 11:54 AM
sd2649's Avatar
sd2649 sd2649 is offline
Driving in Style
Repeat post... oops!
-Steven
1992 SVX Purple and Black 5 speed swap
SOLD
*1993 SVX Silver and Black
*1994 SVX L Barcelona Red FWD
B 4 You's Avatar
#lolsvx
wait. maybe it was $88. i forget. all i know, is that it was a bunch of money that i really didn't have.
thank Jesus for grandmas.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 10-28-2010, 12:01 PM
sd2649's Avatar
Driving in Style
Great news! I had an overheating problem too, it was caused by one of the dumb radiator caps with the little platic pressure release lever. The hood was apparently touching it ever so slightly, letting some coolant vent at running temp/pressure.
-Steven
SOLD
Old 10-28-2010, 12:04 PM
Huskymaniac's Avatar
Uses the ignore feature
OK, update...
*Yeay!*
Good luck! Just curious, did they do any tests to confirm the water pump was bad or was there something that lead them to that conclusion?
Tony
Old 10-28-2010, 12:06 PM
sd2649's Avatar
Driving in Style
To verify a bum head gasket, couldnt you just open the radiator and rev the engine looking for bubbles?
-Steven
SOLD
Old 10-28-2010, 12:12 PM
Originally Posted by sd2649 View Post
Great news! I had an overheating problem too, it was caused by one of the dumb radiator caps with the little plastic pressure release lever. The hood was apparently touching it ever so slightly, letting some coolant vent at running temp/pressure.
I often wonder how many head gasket problems are caused by overheating versus the other way around? This engine runs hot and is not evenly cooled. The uneven cooling causes mechanical stresses which things like gaskets don't like. So now if anything minor goes wrong (radiator cap, water pump, clogged radiator, leaky hoses, low coolant level due to a leak, stuck thermostat, etc.) it will quickly cause overheating which will, again, be uneven and that could cause headgasket issues to develop. It would be interesting to set up a poll of people that had headgasket problems to see how many of them had "other" cooling system problems at the same time and how many know for sure that it was only the headgasket that was an issue.
Can we do polls on this forum?
Tony
Old 10-28-2010, 12:26 PM
Cam Cam is offline
It has been said many times on this forum, and by very many reputable members. The headgaskets failures are most likely related to age. Also how hard you drive your car. If you are overheating and you don't do a headgasket job then you are prolonging the inevitable. Overheating plus age equals eventual headgasket failure. The gaskets are TWO DECADES OLD in some cases. My car overheated on me, and I pulled my engine. There were 7 failures one 1 side! So good luck with your new water pump and timing belt. I wish you many miles of trouble free driving. But I honestly think that your gaskets are on their way out.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 10-28-2010, 01:58 PM
Sold. :'-(
They expected to find the impellers sheared off, but instead found one end blued from heat, and a very difficult pump to turn.
How it didn't destroy the timing belt -> engine is beyond me.
Someone's looking out for me.
Raxles front axles
Old 11-10-2010, 06:06 PM
Sold. :'-(
Thanks for the vote of confidence, Cam. :-/
A couple weeks in, still NO temp issues.
Should be ordering the wheel bearing soon.
~M
Raxles front axles
