Old 01-24-2008, 06:10 PM
Thanks for the reply and info.
blk 92' LSL w/ average mods
Old 01-30-2008, 09:58 AM
Chiketkd's Avatar
Chiketkd Chiketkd is offline
Originally Posted by mbtoloczko View Post
Is an Evo X next? ;-)
Maybe...maybe not. I'll probably stay in the Wacky World of Wankel for my next car purchase.
2006 Steel Gray WRX TR (sold)
Old 01-30-2008, 11:47 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Do I smell Rx7?
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 01-30-2008, 01:08 PM
Banned
ride height adjustment question...
with your kit.. with everything top of the line thrown in, I know you adjust the ride height ahead of time, but is it possible to adjust the ride height afterword when it's installed on the svx or do they need to be removed to be adjusted? If they are able to be adjusted while installed how easy is it to adjust???
Old 01-30-2008, 01:21 PM
Tim's Avatar
Tim Tim is offline
You jack the car up so the wheels are off the ground, loosen the lock with an allen key, then twist the collar until you get to the desired level. Lock the screw using the allen key then put the car back on the ground. Repeat for the other side. The wheels do not need to be taken off the car.
Tim
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 02-24-2008, 12:05 PM
For height adjustment the front wheels do not have to be taken off, however to adjust the rear wheels the complete strut/spring assembly must be removed...
Old 02-24-2008, 12:27 PM
sicksubie's Avatar
Really?????
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 02-24-2008, 12:30 PM
Originally Posted by sicksubie View Post
Really?????
+1
That doesn't make sense to me? The rear adjustment collars look exactly like the front, why would you need to take the suspension apart to adjust them?
Old 02-24-2008, 12:47 PM
Yes, now I am just rehashing what I have heard from tom (wawzat), mychailo, and others over the past 3 - 4 years. Mychailo pre-sets both the front and rear, however, setting of the rear and your desired setting is the most important due to the fact that the rears need to be removed for different ride heights. I do not know the technical reasons for removal of the rear, I am just confident to state that they do indeed need to be removed...
Old 02-24-2008, 12:49 PM
sicksubie's Avatar
that what I was wondering
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 02-24-2008, 12:55 PM
Oh, that's the firmness you're thinking of. The fronts are adjustable because you can reach the top mount by opening the hood. For the rears he pre-sets the firmness because the adjustment knob is not accessible without removing the struts.
Old 02-24-2008, 01:02 PM
Oh ok, so I was confused, just so we are all on the same page, for height adjustment with the koni/gc setup we can do this without removing the rear assembly...HOWEVER, when adjusting firmness the rears must be removed?
To my knowledge both firmess and ride height can be done without removing the strut/spring assembly up front.
Old 02-24-2008, 03:21 PM
94SubieSVX's Avatar
OOC for a while
The last time I had emailed Koni, they said they offer a kit or something of the like that makes it so we don't have to take the assembly out to adjust the firmness. I believe they said it was an extra $90 or so.
bLAh
Old 03-03-2008, 08:12 PM
Banned
would it be possible to install a switch like in late 90's corvettes that allows you to change to firmness from inside???
Old 03-03-2008, 08:24 PM
As far as I know, firmness is usually adjusted with a knob at the top of the strut. If you could put an extension on that knob on the rear struts so it came through the rear shelf you could reach it and adjust to your heart's content. There is a coilover system that has electronically controlled firmness from a controller you can mount inside the car, but it's pricey. Might be Cusco...I can't remember.
