Old 12-01-2012, 12:11 AM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
Re: Wheels that fit the SVX
The ad says that there are two different sized tires on that set of rims and that they're worn unevenly - definitely get new rubber before running them on your car (unless it's a front-driver).
I like the look of those rims. Can't say 100% if they'll fit without issues, but it should be ok; I run an 8" wide rim with 42mm offset with the 225/45 rubber and lowered and I get zero rubbing.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 05-13-2013, 09:46 AM
fasteract7's Avatar
fasteract7 fasteract7 is offline
RX-8 18x 8 rims, offset 52mm, with 235/40-18 Falken's on stock suspension, 1992 LS-L. No rubbing of tires in rear with empty backseat, fronts not even close to touching, with fairly aggressive cornering on mountain roads.
Old 07-06-2013, 08:42 PM
Jvan Jvan is offline
I've used Tribeca wheels w/245/40/18 Yokohama S drive with great success. The only problem I've had was not being able to install the center cap because I've been using the stock lug nuts that came w/the SVX. That was not much of a concern because the rims didn't come w/center caps when I bought them. I have now purchased the center caps and would like to use the correct lug nut. Can anyone recommend the type/length of the lug nuts to use. I can just purchase common acorn open end nuts but not sure the Tribeca rims use a flat washer or tapered ends.
Old 07-07-2013, 08:17 AM
lhopp77's Avatar
lhopp77 lhopp77 is offline
Old Timer (age that is)
I agree. I have not really seen anything I like better.
SVXx2
92 SVX LS-L Silver
96 SVX LSi Red
92 SVX LS Pearl (Parts)
01 F150 4X4 Red
FREEDOM IS NOT FREE
Old 07-17-2013, 07:45 PM
scoobydrvr scoobydrvr is offline
Handful of questions:
Has anyone figured out if it's possible to correct the speedometer reading from a 4.44 swap by fitting a different sized tire (noticed mine reads about 5mph above the actual speed; speedo says 70, GPS says 65)?
What is a good sized tire for the Murano rims? And for the RX8? How is the ride with the short side walls?
1996 SVX LSi : Work in progress, future garage queen
2013 Acura TSX: Mistake
Old 07-17-2013, 08:16 PM
Yes.
I believe that with the 4.44 swap the speedometer read about 5.5% higher than actual.
So a 5.5% taller should read as correctly as we are able with the stock SVX componants.
Old 07-18-2013, 08:05 AM
Yes.
Okay, check my method here (color coded for clarity, mathematical not visual, sorry):
OE tire size: 225/50-16
16" = 406.4mm
(225 * .50) * 2 = 225 - height of upper AND lower sidewall
225 + 406.4 = 631.4 - height of sidewalls and rim for total diameter (mm)
631.4 + (631.4 * 0.055) = 666.127 - compensated total tire diameter
Picking from some standard sizes
205/50-17 = 636.8 mm diameter
215/45-17 = 625.3 mm diameter
225/45-17 = 634.3 mm diameter
225/40-18 = 637.2 mm diameter
225/45-18 = 659.7 mm diameter
So, to get close enough, I need a 17" rim with 215/45-17 tire, right?
EDIT: WRONG!
I goofed up on the math for the tire diameters, current numbers are correct. The 225/45-18 should take care of it well enough.
Old 07-18-2013, 08:28 AM
Using Larry IIIs tire calculator,http://www.subaru-svx.net/photos/fil...yIII/14768.xls
the 215/45/17 would be 6.1mm shorter than stock.
A 225/45/17 would be 2.9mm taller than stock, but would be just as wide as stock.
Old 07-18-2013, 08:46 AM
That's a really neat tool! Doing my math again it seems I need a tire with a diameter of 26.23". According to this, I need a 225/45-18 (25.97") to get close to making up the difference?
Old 07-18-2013, 09:51 AM
Normally I would NEVER recommend a aller tirefor our SVXi, but with 37% more torque in first gear the 4.44 tranny can take it in stride.
If your wheels are wide enough that tire will make a big differance in handling feel.
Old 07-18-2013, 10:13 AM
Is there a better way to compensate for the speedo?
Old 07-18-2013, 11:51 AM
Good question!I have always believed that you could not have too much tire on a car, IF the car was able to handle, or prepared for the bigger tires.
The weight of the wheels and tires is something to consider.
The stock wheels and tires weigh about 40 pounds each.
Heavier wheels and tires are harder to both accellerate and decellerate, making the car slower (to get going)and harder to stop.
Knowing that a 4.44 has MUCH better torque in all four gears this allows a little lattitude in tire sizing.
But back to your question.
I called Mike at ECUTune to ask him if He could make some 4.44 speedometer compensators.
This might be a great thing for those out there with 4.44s and want to keep the stock tire diameter.
On my SC Claret I went with bigger tires and wheels.
It has the torque, brakes and suspension to handle the big wheels and tires that are actually lighter than our stock ones.
Old 07-18-2013, 01:55 PM
Have they already been developed and he just has manufacture them or would this be a new product? I would be pleased as punch to be able to put on a smaller (read: standard) tire...
Old 07-18-2013, 04:08 PM
This would be a new product that He would have to develope/create.
Old 07-20-2013, 03:01 PM
kingbobdole's Avatar
kingbobdole kingbobdole is offline
Gr sti wheels. 245/40r18
