Old 09-05-2011, 08:00 PM
LetItSnow's Avatar
My 10th Subaru is a WRX
Any suggestion from the peanut gallery <LOL>
Somebody doesn't like it.
Somebody thinks it'd be cool.
Somebody says psh, do wa'cha want - it's your car.
I think that's how it goes?
Old 09-05-2011, 09:12 PM
Rod.'s Avatar
Rod. Rod. is offline
Did 1,800 km this weekend to pick up a non-running '92 that will hopefully be an engine donor for my '97. Both are now at my mechanics for the estimate.
The '92 has a busted tranny so it came home behind my Ridgeline. Bit of an ordeal to load it onto the dolly -- had to get a tow truck to winch it on. It hasn't run in 5 years, so this could be a pig in a blanket, but here's hoping it's mostly good...
Here's a photo at the mechanic's of the '92 in the foreground and the '97 waiting patiently in the back.
http://db.tt/i4VVF4O
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 09-08-2011, 09:53 AM
Gamesy's Avatar
Gamesy Gamesy is offline
installed my 4ch amp
Old 09-09-2011, 11:01 AM
Decided to spend 5 hours and sand down my Hood. Looks much better but not perfect. The spots that look like marks you see in the front is a refection of the clouds . Camera does not do it justice
Old 09-09-2011, 11:30 AM
Maybe you should have it clear coated?
Old 09-09-2011, 02:06 PM
That is what caused the problem in the 1st place the clear got cloudy . I had to sand it off. i just had a Graphic made for the hood scoop.
Old 09-11-2011, 09:24 AM
Well the Roof and the Hood came out good. a little more touching up needed .
Old 09-11-2011, 10:04 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
I uncovered mine for the first time in 2weeks to let it see some sun. :/
Old 09-13-2011, 06:39 AM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
After 3+ years of SVX ownership, I have finally done the power mode mod. I kick myself for not doing it sooner, what an amazing difference. How this was not standard switchable option for USDM is beyond me.
I almost feel I need not bother with a QC unit at this point... but alas, I have one so may as well?
1994 subaru svx le 112k
Old 09-16-2011, 10:20 PM
Jazlyn Jazlyn is offline
Cool Re: What have you done to your SVX (or other Subaru) today?
Bought my first svx today! And drive it all the way home. It needs need brakes and probably rotors, and has a but of rust, back wiper and antenna doesnt work, and it kinda revvs upe while cruising sometimes, but other than that, I love it!
Old 09-17-2011, 12:09 PM
Transmission slipping = bad news. Budget for a replacement, and expect it to go sooner or later. Drive with it in 3, not D - do not let it slip.
Get good rotors, crappy ones tend to get warped.
Old 09-17-2011, 09:54 PM
Turbone Turbone is offline
Banned
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
After 2yrs of sitting (mostly my fault) I got the trans in and am installing a new t-belt kit, waterpump, plugs and a coil pack. Its pretty dirty from sitting out, so I'm also cleaning it up. Will need a few more parts to get it road worthy, I'll be posting in the Wanted Forum.
Old 09-18-2011, 01:56 AM
92 SVX 92 SVX is offline
After getting my new rear sway bar thursday im finally putting it in, finally because I feel I have waited for a very long time to do this. lol
Old 09-18-2011, 07:25 AM
LetItSnow's Avatar
I figured I'd do some easy work this weekend. I have a couple of dash button bulbs that weren't lighting. I was able to replace the surface-height ones, but the sunk-in ones are a pain in the arse to remove. Anyone have a good tip on how to do this?
Old 09-18-2011, 08:59 AM
Old Fogey
Tweezers perhaps?
I had the pleasure of replacing the back-up lamp switch on the mule (wagon) and figured out how I'm gonna get the clutch hydraulic hose swapped out for a stainless one. Just have to be sure the wife's around to help me bleed it.
BlackBerry got all the dust washed off and I got a start on polishing her up with the DA. Hood and roof are Gleaming!! Front fenders and doors are next.
Glenn
