#31
Re: Parts availability: How near is the end?
I got it out of the back this morning, omg that thing weighs a ton. Officially the heaviest engine I've ever pulled! I had to slide it down a pair of 2x6s praying it wouldn't fall or roll forward on my feet. Anyone know how much it weighs in at?
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
#32
$500+
Keith ![]() |
#33
Well aware and part of my motivation
#34
In my 5+ years of SVX ownership, I've bought:
(1) crankshaft pulley, (4) antisway bar bushings, (0) ball joints, (4) some rear wheel bearings and seals, (1) gasket kit, (4) hood struts, (also 4 trunk struts) (2) radiator hoses, (1) radiator, (0) driveshaft, (2) axles, (1 used) CD player, (2) cam seals, (1) crank seals, (1) timing belt, (2 pr.) brake pads, (2) rotors, (0) calipers, (0) inner tie rod ends, (0) outer tie rod ends, (0) an extra 3.3, (1) water pump, svxfiles, I'd say your list is dead on the money. I hate the thought of buying-up stuff that's in abundant supply, even if delivery takes a week or two. What I wish we knew is what's almost gone, not just from these shores, but for good. dcb |
#35
The anti-sway bar links now list for about $70.00! Everything is going up way more than it should! We know that will need them, we might as wll buy the stuff before we can't afford it!
#36
Ask cozykat (Marisa) for a list of everything she has bought, or is buying on a regular basis to use as spares.
Here list is very comprehensive and impressive to say the least. Every imaginable part. Engine wiring harnesses and anything else you can possibly think of... ![]() ![]() But then, coming from Texas, she does things in a BIG way. ![]() ![]() .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 01-11-2010 at 09:40 AM. |
#37
She has nicer parts than me! Hell, even Carlos could see that! ![]()
www.svxfiles.com The first SuperCharged SVX, ![]() the first 4.44 gears, the first equal length headers, the first phenolic spacers, the first Class Glass fiberglass hood, the first with 4, 4.44s in his driveway ![]() Fiberglass Hood thread My locker 4.44 Swap link Last edited by svxfiles; 01-11-2010 at 02:00 PM. Reason: Misspelled even, Don't tell Di! |
#38
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ... 203,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
#39
Rear strut mounts—postscript:
I'm guessing Subaru never figured these to be a replacement wear part. Man, mine were shot. Not a spot of rust in the doors, no bubbles in the paint, no alarming signs of corrosion in this car at all, but the mounts looked like salvage from Titanic. What are these things made of, some crazy high-carbon alloy? dcb |
#40
I think the best way to do it, is to buy and keep parts that cannot and will not exist in aftermarket form, and which are perishable by time and age (rubbers, seals, glass, etc...)
Marisa is right on buying and gathering parts. But I wouldn't go as far as buying OEM struts. The mounts are questionable...
Danny 1994 Silver SVX in hybernation, awaiting for the monsterous awakening (Lebanon) ![]() 1967 Mercedes-Benz 250SL Euro Specs, Hard/Softtop, White/Red. Under Complete Restoration ![]() 2013 Mercedes-Benz SL350 Euro Specs, White/Red. Mint... Another step into SL Collection. ![]() |
#41
A buddy of mine was eyeballing an SVX local to him, and I couldn't not offer the concerns that we've discussed in this thread.
Windshields are what they are, but as an SVX society, our next direction will probably involve custom bits to allow our cars to accommodate more common hardware. How crazy would it be to be able to select from the entire line of Impreza or Legacy suspension parts or brakes or... ?
Disclaimer: The above post is on the internet. |
