Old 01-02-2009, 03:52 PM
svxxx26's Avatar
svxxx26 svxxx26 is offline
Headed to Texas...
Re: Oil filters
I have a question about the filters, hopefully someone may know.
My common practice when changing oil is to fill the new filter with oil as much as possible, so the filter itself is "primed" upon startup. The OEM Subaru filters and the Purolator OEM-size filters allow this - put the Porsche filter does not.
This indicates a difference in construction - and what the difference is I don't know. I like the concept of a larger filter, just have my doubts as to why it doesn't allow "pre-filling".
Any thoughts on that?
Jerry
2005 Baja Turbo
2008 Ford Crown Victoria Police Interceptor
jnj7707@yahoo.com
Old 01-02-2009, 08:10 PM
Re: Oil filters
You could disconnect the ignitor before you actually start the engine.
This allows the bearings to get pre-oiled before you add the pressure of a running engine.
I always do this after the oil pump gets replaced or resealed.
Old 01-02-2009, 08:36 PM
liamrh's Avatar
liamrh liamrh is offline
Re: Oil filters
I would assume that it is because it has a better anti-drain back valve.
