#406
Taking the project in to be inspected so I can finally register it.
#407
Changed the fluid in mah supercharger.
Disclaimer: The above post is on the internet. |
#408
These are PIAA extreme 1157 tail lights. LED marker lights and 6000 K HID head lights . Dome and door are LED also . I don't if they show up in the picture
#409
Is there someone on the brake? If not, that is pretty extreme.
#410
No they are the running lights, no brake on .
#411
If you want much brighter brake and tail lights, you can't do better than "Brite Bulbs" from Ron Francis Wire Works. Blows everything else out of the water and a lot cheaper than the PIAAs.
That's all I use. See my post HERE .
#412
I cleaned it for around 9 hours in preparation for Japanese car day tomorrow. I don't feel embarrassed leaving my hood open now.
#413
LETS see it ....
#414
After a long wait / hunt, I have now installed a set of silver BBS 05 STI wheels in almost-mint condition, wrapped with new Nexen N6000's, to go with the new paint job on my 92 Ebony.
It looks very nice indeed.
92 SVX, Ebony Mica 186,000 kms 92 Mercedes Benz 300CE, Arctic White 187,000 kms |
#415
Ran around town asking people "hey can you fix my radiator" and getting a lot of grim faces.
#416
#417
My low beams don't switch off when the highs go on. I thought they were supposed to? It's bright as ****.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. Last edited by NikFu S.; 08-17-2011 at 02:43 AM. |
#418
Got an appointment with some aluminum pros to solve my radiator problem this Monday.
#419
So I bought new rear wheel bearings cause I could've sworn thats what the noise was. I began taking the hubs off to have the new bearings pressed in. In the process of taking the parking brakes apart I discovered the bottom spring by the adjuster was unhooked from one of the shoes and rubbing on the ABS rotor thing.
I'm so happy the noise is gone.....and I have a set of bearings and seals for when I do need them
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
#420
did the LED strip in grille mod. how to writeup will be here soon.
